10-27-2011, 06:13 AM
Member #1414
the dalton makes no change to the secondary,none is needed.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
10-27-2011, 08:04 AM
Member #19254
don't touch the secondary
2009 polaris xp 850 epsmossy oak ,28" zilla's , k&n filter , pure polaris front brush guard , pure polaris front rack bag , pure polaris gun scabard , dalton clutch kit. if you own a 850 xp and don't run a dalton clutch kit YOU'RE NUTS !!!!!
11-06-2011, 07:58 PM
Member #3405
well here it is. put the white spring in the secondary that they gave me. took her for a ride and still has a harsh backshift. its not as bad but still too much. this is the reason i have kept my father from taking it for a spin. when i got home i swapped the stock springs and weights back in. back to stock. took it for a quick ride around the yard. backshift is ok now, i think that was the problem as you guys said " leave the secondaries alone."
stock the backshift is a little harsh, any increase in this is too much. going back to stock made it more managable. the increase in the engament and the harsh backshift was just not worth it.
the guys at EPI told me to try it and if I wasnt satisfied, give them a call and they would work it out with me.
threw a pic in here to show how i did it. :-) my back cant handle bending over for too long so the hoist in the ceiling helps like you wouldnt imagine.
Ken
2011 850 XP EPS
Browning LE
27" XTR's
Atv Guru Cobra series brush guards
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Polaris Pursuit camo
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Racer Tech 2inch lift
Makin Trax springs
Old enough to know better but, still too young to care!
http://s859.photobucket.com/home/cableguy657/allalbums
11-06-2011, 08:12 PM
Member #19254
pretty slick !
11-06-2011, 08:18 PM
Member #3405
Thanks,
I got the hoist positioned so i can back the truck or trailer under it to unload anything i can get a strap around. butchered a few deer with it and when the mower needs to have the blades changed for fresh sharpened ones and have the deck cleaned.. it has to be one of the best money i ever spent. its a HF 440 single 880 pound double capacity. now i just need to find time to clean the garage.
2011 850 XP EPS
Browning LE
27" XTR's
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Makin Trax springs
11-07-2011, 04:28 PM
Member #5629
It ain't a mancave if it ain't a lttle dirty! HaHa
Con
02-24-2012, 06:04 PM
Member #23274
Wanna sell your set up? I got a boy here that could use it! He just distroyed his whole clutch! Let me know.
02-24-2012, 08:58 PM
Member #3405
i was able to return the kit to EPI. I bought it directly from them and worked with them as i was trouble shooting it. they stood behind their product and beings it didnt work for me with my application they took it back and refunded my money. so the only money i lost on this was the original instal by the dealer, return shipping cost and my time removing it and putting it back to stock. i got a learning experience and now know more on how the cvt works.
2011 850 XP EPS
Browning LE
27" XTR's
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Makin Trax springs
2007 polaris sportsman 800 epi sport utility, 28 zilla on polaris xp stock wheels, 850 xp epi clutch kit install, best clutch for 2011 850xp, dalton clutch kit 2011 850 xp, do i need a clutch kit on my atv, does an epi clutch work, does the epi sport utility kit work, epi atv clutch springs, epi clutch install cost, epi clutch kit 2011 850 xp rpm engage, epi we437029 clutch, how do i know what clutch kit to buy for my atv, polaris 850 clutch kit, polaris atv epi red springs, powered by vbulletin sport utility, what is the best mud clutch kit for polaris 850xp, what secondary clutch spring will give me more low end on polaris 330, which epi clutch kit is right for me, why did my 06 polaris clutch jammed
