10-23-2011, 11:31 AM
Member #3405
EPI sport utility clutch kit
I have a 2011 850 XP that my dealer installed a EPI WE437029 clutch kit.
It gave me a higher engagment, about 400 rpm. I have learned to get by with this. But really dont care for the higher engagment. my problem is the back shift. It is so harsh that it is like i jammed the brakes on when slowing down. On down hills i find myself being into the gas enough to keep it from back shifting and i have to be on the brakes to keep it slowed down.
Unless there is something that can be done with this I have no option but to remove the kit and go back to stock. I dont feel that i could let a unexperinced rider ride my atv. it is that bad. the only time i am ok with this harsh backshift is when i really dont want to go fast coming down a hill. on some of the big coal hills i dont mind being slowed down so much.
with the adc on coming down a hill in high range it would slow it me down to 4 mph in low it would be about 2. now with the kit it is 2 in high.
what can be done to make this better, a different spring? back to the stock springs? again the kit was installed by my dealer.
the stock parts i have, the springs are red with a white stripe.
any help you can give me would be great as i am not happy with this kit and riding now is a real pain, taking the enjoyment out of riding.
I have never had to use low range on the trail, and never had any belt slippage, but the price to pay for this is not worth it to me.
thanks,
Ken
2011 850 XP EPS
Browning LE
27" XTR's
Atv Guru Cobra series brush guards
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Polaris Pursuit camo
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Racer Tech 2inch lift
Makin Trax springs
Old enough to know better but, still too young to care!
http://s859.photobucket.com/home/cableguy657/allalbums
10-23-2011, 12:52 PM
Member #5629
After putting my 27" tires on my bike, the only thing I have changed in my clutch is the primary spring. I put a Dalton spring in the primary. This raised the engagement by 200 rpm. To me, this is about right. I would think EPI would have a spring that would match that one.
As for the aggressive backshifting, the spring in the secondary would appear to be too much. IMO
If I were you, I would give EPI a call to explain how the bike is reacting to the kit, let them know how you would like the clutch to work, and see if they have any suggestions.
Con
10-23-2011, 01:17 PM
I have a story you need to read.. CVT Clutching 101
THEN call the boys at EPI, they will set you straight..
10-23-2011, 02:14 PM
Member #3405
i am definitely getting some help that i needed from the forum. but with EPI as a supporting sponsor do they answer questions like I have on here? that is why i posted my question on here.
2011 850 XP EPS
Browning LE
27" XTR's
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Makin Trax springs
10-23-2011, 02:56 PM
Member #3405
I read the article and will give EPI a call in the morning to see what they can do to help. With the 2011 Xps it seems that the helix is fixed and you cant change them out unless you get a new secondary clutch. it seems to me that my problem is primarily there with the harsh down shift on deceleration. I will let you how the phone call goes.
2011 850 XP EPS
Browning LE
27" XTR's
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Makin Trax springs
10-24-2011, 06:22 AM
Member #1414
of the 4 model years of the 850xp the 2011 has the best clutch setup and there is really no need to change it from stock. this is why dalton makes no kit for the 2011,it is good to go stock. the EPI was a waste of money,i would see if you can return it.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
10-24-2011, 10:37 AM
Member #3405
I agree with the waste of money part. I did see that Daulton didnt make a kit for it but didnt look into it. so in the end it cost me some money. it just figures that i decide to change a clutch on a bike that was good from the factory.....
i just got off the phone with EPI and was told to change the secondary back to stock. this will get my back shift back to stock...
called them back to return the kit and they want me to try a different secondary spring. EPI folks are good to work with. Told me to call back and let them know how it worked for me.
2011 850 XP EPS
Browning LE
27" XTR's
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Makin Trax springs
10-24-2011, 11:55 AM
Member #1414
ken that 400 rpm higher engagement is way to high for a trail rider,that is for real big mud tires and big/deep mud holes. that higher rpm will cause strain on your drive train,like the small/cheap china made axles polaris started useing on the 2011.i would take the whole kit out and put it on ebay and take whatever you can get for it.
09 850XP EPS
10-26-2011, 05:51 PM
Member #19254
dalton told me they should have a kit for the 11 before the snow flies. they should have never touched the secondary because from the factory they are setup perfectly regardless of year of xp 850. dalton is the only way to go if you are clutching a sled or a quad. i still can't believe how hard mine pulls now.
2009 polaris xp 850 epsmossy oak ,28" zilla's , k&n filter , pure polaris front brush guard , pure polaris front rack bag , pure polaris gun scabard , dalton clutch kit. if you own a 850 xp and don't run a dalton clutch kit YOU'RE NUTS !!!!!
10-27-2011, 04:01 AM
Member #3405
with your kit the secondary was left alone?
should i even bother putting the new secondary spring in, just put the stock spring back in?
2011 850 XP EPS
Browning LE
27" XTR's
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Makin Trax springs
2007 polaris sportsman 800 epi sport utility, 28 zilla on polaris xp stock wheels, 850 xp epi clutch kit install, best clutch for 2011 850xp, dalton clutch kit 2011 850 xp, do i need a clutch kit on my atv, does an epi clutch work, does the epi sport utility kit work, epi atv clutch springs, epi clutch install cost, epi clutch kit 2011 850 xp rpm engage, epi we437029 clutch, how do i know what clutch kit to buy for my atv, polaris 850 clutch kit, polaris atv epi red springs, powered by vbulletin sport utility, what is the best mud clutch kit for polaris 850xp, what secondary clutch spring will give me more low end on polaris 330, which epi clutch kit is right for me, why did my 06 polaris clutch jammed
