12-11-2011, 01:41 PM
IF the vent line is connected its likely under vacuum and IMHO SHOULD NOT. The vent or the axle for that matter was never designed to have vacuum on it.
I would plug the line and run the vent up as high as you can and tie it in place. It may be worth the couple quarts of 90W to pull the cover, drain and refill the axle. Most people never change the oil anyhow and it likely over due...
BTW, OVER filling can cause it to puke too...
12-11-2011, 01:49 PM
Member #20942
sure thing  Good Luck
Wheeler:2012 Polaris Sportsman 500 HO, Polaris 3500# Winch, 48" Cycle Country Plow, 3 Light Mod, HID Pod light, Heated Hand Grips, Reverse Override
Vehicle: 1998 Jeep Wrangler, 4.0I6 5 speed, 4'' rough country lift, 33" Mickey Thompsons
Bike: 2005 Suzuki Boulevard C50 Limited Edition W/ Ghost Flames
12-11-2011, 04:54 PM
Member #3687
Originally Posted by tt425
Can you post a pic of it? It might be equipped with rear heat and air. Antifreeze maybe? Are you sure a vent line from the rear differential is not leaking?
Glad I could help with my 23yrs experience in auto parts.
12-11-2011, 06:01 PM
Member #20942
a second opinion is not always a bad idea. but all in all you were probably right
12-17-2011, 08:27 AM
Member #10604
the wife had the oil changed 3 weeks ago and they told her that it was time to change the oil in rear end at a cost of $75.00 and now its doing this. so i guess i will take it back and see if they over filled it. thanks
fuel vent filter on fuel pipe 2000 jeep cherokee, jeep grand cherokee rear axle vent leaking, powered by vbulletin jeep dealer, powered by vbulletin maxxis motorcycle tires
