Go Back   Polaris ATV Forum > Polaris ATV Classifieds > Everything Else
Everything Else This classifieds section contains Non-ATV related items. If your trying to sell your car, truck, boat, motorcycle, electronics, etc this is the place.
Old 12-10-2011, 02:30 PM
utvatv800's Avatar
Member #10604
jeep grand cherokee
i was wondering if any body can tell what this is? I have a 2003 grand cherokee and up in the left rear quarter panel behind the rear tire there is something that looks like some kind of pump and it is leaking oil that smells like rear end grease, can any one help me?
Old 12-10-2011, 02:36 PM
tt425's Avatar
Member #3687
Can you post a pic of it? It might be equipped with rear heat and air. Antifreeze maybe? Are you sure a vent line from the rear differential is not leaking?
Old 12-10-2011, 02:52 PM
cwlongshot's Avatar
Can you post a picture?
I am at a loss as to what that is... I have been around jeeps for years.. just not this new.
Old 12-10-2011, 02:56 PM
utvatv800's Avatar
Member #10604
no the diff isnt leaking, the oil is coming out of this thing. The dealer was closed when i noticed it. it has a small rubber hose going to it. It smells like 90 weight oil
Old 12-10-2011, 02:57 PM
utvatv800's Avatar
Member #10604
sorry no camera
Old 12-10-2011, 04:29 PM
JeepWave's Avatar
Member #20942
posted it on the jeep forum that im a part of. ill see what them guys say and let you know.
Wheeler:2012 Polaris Sportsman 500 HO, Polaris 3500# Winch, 48" Cycle Country Plow, 3 Light Mod, HID Pod light, Heated Hand Grips, Reverse Override
Vehicle: 1998 Jeep Wrangler, 4.0I6 5 speed, 4'' rough country lift, 33" Mickey Thompsons
Bike: 2005 Suzuki Boulevard C50 Limited Edition W/ Ghost Flames
Old 12-11-2011, 03:23 AM
JeepWave's Avatar
Member #20942
Here is one response i got back from last night.
Originally Posted by Gran_Paradiso View Post
I have the same smell from my drivers rear wheel area. I've had all my axel seals changed and its still there a little bit its only after you stop. Brakes are fine too. The unit under the rear quarter I believe its part of the emissions system for the gas tank or there of.
the part he is referring too is the LDP (Leak Detection Pump) which is run by vacuum off the engine to check for fuel leaks and blockage. there is also a charcoal canister down there too. if anyone else sends me a reply ill send it on too you
Old 12-11-2011, 04:01 AM
cwlongshot's Avatar
Thats emmission control equiptment... NONE of which has 90 weight in it...
No camera on your cell phone?
Old 12-11-2011, 07:06 AM
JeepWave's Avatar
Member #20942
yeah i know. but thats all i can think of that would be back there. im stumped. nothing should have oil in it i dont think. this came in too:
Originally Posted by WJWKXJZJ View Post
I could be wrong, but isn't that area where the rear axle vent is routed to? You might be puking gear oil up the vent hose and it's dripping down over the vapor canister?
The item you see is the evap canister and a solenoid for the purging system. The tank vapor lines are fed to it, and a stainless line runs along the unitbody frame rail and into the driver's side of the engine compartment.
Old 12-11-2011, 01:37 PM
utvatv800's Avatar
Member #10604
you might be right, it might be the axle vent and its all over that soleniod. I hope that oil dont hurt the soleniod, there are some jeep guys coming over to look at it later. thanks to every body for the help, will let you know what i find out
fuel vent filter on fuel pipe 2000 jeep cherokee
jeep grand cherokee rear axle vent leaking
powered by vbulletin jeep dealer
powered by vbulletin maxxis motorcycle tires
Jeep Tornado Kenny Rogers Everything Else 8 09-30-2011 02:53 PM
'07-'11 Jeep Wrangler parts Willy Everything Else 0 05-17-2011 09:26 AM
Easter Jeep Safari 2011- Anyone going? Discount Tire Discount Tire 0 04-15-2011 03:27 PM
Rebuild a Jeep in under 4 mins. blueline15 Around The Garage 3 11-20-2010 08:14 AM
Doug Eichner takes Ninth Pro Win at the 40th Anniversary Lake Elsinore Grand Prix Admin ATV Racing Discussion 4 08-20-2010 08:05 PM
