02-04-2012, 06:00 AM
Member #11494
Originally Posted by JJOHNSON
Thanks for the great information
I do have a question. I am not an electrical guy at all!
If you do not use the 87a on the SPDT 5 pin relay then can you use the SPST 4 pin relay?
Joined the sight looking for this exact mod and found it thank you
Welcome
Not sure on the SPST, not much of an electrical guy myself as I fix humans for a living. I have read about 4 pin relays that work, but I am unsure if you need the double throw in order for it to work properly. Maybe someone who knows can chime in here....
2010 Sportsman 500 H.O.
02-05-2012, 12:05 PM
Member #22920
went a head and gave it a shot.
4 prong SPST 30 amp relay worked
02-05-2012, 12:26 PM
Member #11494
Awesome! Glad to know that the SPST works too!
02-12-2012, 05:50 AM
Member #16284
Hi there, what will this mod do for me? (did I miss the explaination somewhere?)
02-12-2012, 06:29 AM
Member #11494
If you own one of the value line (500, 800) this will get all 3 lights (low beams and high beam) to light up at the same time as opposed to one or the other.
02-12-2012, 09:42 AM
Member #16284
Thanks B, after I posted I realized I missed like 2 pages of threads and saw one of the pics. I'll put this on my to-do list
02-17-2012, 06:19 PM
Member #21525
3 headlight mod
IF you go to "ebay" and type in '3 headlight mod' you will get an item listed by a "limolarry" for just under $10.00. This mod is very simple as you only have to clip two quick connecters into the green and yellow wires from the headlight bundle. It works very well. It took less than 10 minutes it install.
02-18-2012, 02:14 AM
Member #11494
Thank you for posting this, however and certainly meaning no disrespect, this is a post designed to aid people in doing a 3 light relay modification in this interest of never putting the switch in harm's way. Although many people have never had a problem with the diode modification a few members have fried their switch and regretted not putting the relay in initially.
02-18-2012, 01:29 PM
Member #19705
Thank you for posting the relay mod. I did this mod today, and actually enjoyed how easy it was. I also purchased the relay and harness, and soldered the connections. I wanted to make sure i never had an issue using clips. For anybody that doesnt think they are savy enough to do this mod, well dont worry, its very easy, and straight forward, no surprises, went just like the video.. thanks again..
02-18-2012, 01:36 PM
Member #11494
Glad it helped! And welcome to the forum
06 polaris headlight relay mod, 3 headlight kit polaris sportsman, 3 mod relay kit, atv headlights polaris all 3 headlights, end zone, kulpmont pa, how to do 3 light mod on polaris sportsman video, polaris 3 headlight mod, polaris 3 light mod, polaris 3 light relay mod, polaris atv forums how to do a 3 headlight mod complete with video, polaris atv high low headlamp adaptor, polaris headlight mod, polaris headlight mod relay, polaris headlight modification, polaris headlight relay mod, polaris sportsman 3 headlight mod, polaris sportsman 3 light mod, polaris sportsman 500 all 3 headlights, polaris sportsman headlight mod, sportsman 3 light mod
