how to : Polaris Sportsman remove starter - pics - Page 2 - Polaris ATV Forum
Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > Polaris ATV How-Tos
Polaris ATV How-Tos Polaris ATV How-Tos, Guides, FAQs put together by the PolarisATVForums.com membership.
  #11 (permalink)
Old 08-27-2012, 07:04 AM
Lollygagger77's Avatar
Member #19655
Originally Posted by xenon View Post
We just did the same thing on our 2007 500. starter from DB electric rebuilders, also replaced the bendix ($25).
Ours was not a X2, the bottom screw was a booger, just enough room , the head hits the back of the cover behind the clutch assembly. had to use ong needlenose and wrench, turning aobut 1/4 turn at a time.
the bottom screw is tricky, but it can be done.
My bottom screw on my 500 is just sitting there not screwed in.. I could not get it to thread in... so hopfully the top screw is enough to hold it in... the bike is not ridden aggressively so I am not too worried about it...
NEW ADDITION: 2016 RZR 900S w/EPS
2012 Polaris 850 XP HO w/EPS
-28" Terminators
-HD Springs and JCCAPRI bushings
-QSC Clutch kit
-3500# Polaris winch with Synthetic Rope
-Polaris Front Brush Guard
-Polaris Lock n Ride front and rear storage
-Polaris Mid Lock n Ride Windshield (smoke)
-60" Warn ProVantage Plow
-Symtec Hand Warmers
-Quadrax Rear seat w/foot rest kit from ATVSUPERSTORE - Square Tube
Old Machines:
2006 Sportsman 800 EFI, 2005 Sportsman 700 Carb, 2004 Sportsman 500HO Carb, 2000 Sportsman 500 Carb
  #12 (permalink)
Old 08-27-2012, 07:23 AM
dog812's Avatar
Member #19217
Place a flathead behind the head of the bottom screw and apply some pressure in while turning the wrench , it will thread back in.
And as for the guy with the problem starting. You wont really know whats wrong till you get everything apart. When you take the recoil housing off you will be able to diagnose both your pull start and your bendix ( = starter drive)
  #13 (permalink)
Old 08-27-2012, 04:35 PM
ItODDospeed's Avatar
Member #1555
The starter drive is different from the bendix...right? I was going to go with this combo right here...
DB Electrical - STARTER DRIVE Combo POLARIS ATV 325 335 425 500 PA102 COMBO SMU0061K 18645
I was going to assume that I had the same problem as you, or at least it make sense to me that I did from your posts. The bendix is the part that you should of replaced with the starter the first time right? I'm going to replace both when I tear it down, but what are your thoughts?
My particular situation, if the bendix is malfunctioning, then isn't it plausible that it's why the pull-start won't make a compression stroke? The 4-wheeler ran fine right up till it quit starting from the pull-start. Previously, the battery had sat in storage, but it started first try. By the end of the weekend it wouldn't start under the electric start. I used the pull-start till the end of the day (Sunday), got it home, and used the pull-start to get it off the trailer. The next morning, I went to put it up, and the pull-start went limp after the first pull. By limp, I mean it will recoil, but would not make a compression stroke. When I put the new battery in it had the same exact behavior as it did when it wouldn't start before I started to use the pull-start. I even hit the side of the pull case with a rubber mallet as per a thread out here, but it was to no avail.
Now I'm starting to think that the reason some need to hit the pull-start side is, because of the bendix malfunctioning, or ready to fail...
I thought I had a grip on this situation, what do y'all think? Am I wrong on with what I'm assuming?
I prefer my cars and bourbon from Kentucky. ~Me
  #14 (permalink)
Old 08-27-2012, 04:57 PM
WilliamBos's Avatar
Member #5254
Bendix is a brand name for a starter drive, like mentioned above.
Thanks,
Will
2012 Sportsman 400HO - 5,800KM and counting.
25" Traxion Grippers
Warn RT 25, Warn Hawse Fairlead, Synthetic Rope, Glacier III plow, Kolpin Rear Trailbox L&R Mounts.
6" Front LED Lightbar
Polaris HD Front coils
Polaris Hand & Thumb Warmers.
  #15 (permalink)
Old 08-27-2012, 05:27 PM
dog812's Avatar
Member #19217
Yeah that is the correct combo..
you might want to take your recoil housing off first , make sure your starter drive / bendix actually needs replacing. Literally takes 5 mins..
  #16 (permalink)
Old 08-27-2012, 05:35 PM
Member #1555
dog812, take the recoil housing off first and check what first? That that piece (the other part in the combo that I showed? Moreover, what is that part called?) is functioning properly? How do I check my starter drive?
I'm really new to this, so thank you for everyone's patience, and help.
  #17 (permalink)
Old 08-27-2012, 05:41 PM
BadjerJim's Avatar
Member #29465
This is a great post with pictures, thanks all!
  #18 (permalink)
Old 08-27-2012, 05:45 PM
dog812's Avatar
Member #19217
you will see in my latest pics on this thread, the picture of the bendix or starter drive, whatever you want to call it.
It sits just on top of the fly wheel basically.. as soon as you open the recoil housing, it will basically be the only other thing in there.
It will just come out, no tools. Make sure its extending and retracting. Mine, as you can see from the picture, was stuck in the extended position..
The recoil housing removed. You can see where the bendix sits right above the flywheel. You can see the little indent where the end sits.
Bendix 's
Basically your starter turns, the motion causes the starter drive to extend, the teeth grab the flywheel , turns it and starts the bike. Then when you turn the key back, the starter stops and the starter drive should retract back so its not touching the flywheel anymore. Or what happened in my case, it did not retract and was spinning as fast as the flywheel was spinning, which was too fast for the starter and burnt it out.
  #19 (permalink)
Old 08-27-2012, 06:24 PM
Member #1555
bendix = starter drive (on the flywheel)
starter = starter
That threw me for a loop.
I firmly believe that what happened to you is what has happened to me. My bendix was not releasing immediately and burnt my starter out. The sound it made when I started it was always a horrible sound on the flywheel side. I will look at the bendix first, take some pics, and get back out here. I want to order the parts now, but I will wait until I see the bendix. I will have to wait till the start of next week one way or another, because...
I am currently waiting for a new coil-pack on a street bike, so I have to wait a few days. Moreover, one of my plug wires has to be ordered from Japan. Yeah! I have a garage stall for all my motorcycles, and have a method to my madness for tear down. I only have so much space that I'm afraid of getting the two bikes confused one way or another. Like I said, limited DIY capabilities.
Thanks for the help dog!
  #20 (permalink)
Old 09-30-2012, 08:26 PM
idaho_flyfisher's Avatar
Member #29582
stripped starter bolt
i replcaed the bendix in my 2006 sportsman and had some problems while trying to take off the starter. the bolt that will not back out all the way has becomed stripped to some degree because i messed up. any idea how to get that bolt out given the circumstances?
Tags
diy, polaris, sportsman, starter
02 polaris sportsman 700 starter removal
changing stater n bendix polaris 500
how to change starter on 2007 polaris
how to remove starter on 2015 sportsman 850
how to remove starter on a 2011 polaris ranger atv
how to take starter off polaris sportsman 850
polaris ranger starter removal
polaris sportsman 500 starter drive diagram
polaris sportsman 90 starter removal
polaris starter #3084981
youtube changing a starter on a 200 polaris sportman
how to remove starter polarity ATV General Discussion 3 09-07-2011 10:12 PM
Remove Starter rdavila343 ATV Repair and Maintenance 3 08-28-2011 07:21 PM
Remove Starter From a 1994 Polaris 300 4x4 hvyw8 ATV Repair and Maintenance 6 05-04-2011 04:43 AM
How can I remove the recoil starter from a 94 sportsman monster ATV Repair and Maintenance 5 02-28-2011 04:43 PM
How to remove a starter? itscody ATV Repair and Maintenance 3 06-19-2010 08:45 AM
