doing away with 2 cycle injection pump - Polaris ATV Forum
Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > Polaris ATV How-Tos
Polaris ATV How-Tos Polaris ATV How-Tos, Guides, FAQs put together by the PolarisATVForums.com membership.
Old 03-07-2012, 07:45 AM
mr_king1967's Avatar
Member #23923
doing away with injection pump
i have a 1995 explorer. i want to pre mix my fuel. i need to know do i need to remove the injection pump.i dont want it to lock up or anything.i have just rebuilt the engine and gear box.do they have a kit to cover where the pump is or will it be ok to just leave the pump mounted and run dry?
Old 03-07-2012, 08:21 AM
buddy_1's Avatar
Member #15674
Yes there is a block off kit available through High Performance Designs, Inc .
I know the "VOICES" aren't real but they have some great ideas.
1999 Sport 400 2x4
Complete rebuild w/Wiseco piston by Todd Kerby, Comet clutch, Swamplites front & rear, 03 Predator Rear Hubs,
ITP Pro Baja Wheels (4x156 front & rear), DG Front Bumper, Fuj Rear Grab Bars and RZR Belt
Old 03-07-2012, 08:25 AM
Member #23923
thanks buddy i will check out your site.you where a great help.it seemed no one knew the answer.thanks
Old 03-07-2012, 01:48 PM
RENOBADBOY's Avatar
Member #23274
I don't understand the purpose for doing this. Can't be weight savings. All it does is foul up a gas can. What am I missing???
Old 03-07-2012, 05:28 PM
bastard's Avatar
Member #23426
If the fuel is already pre-mixed there is no chance of an oil pump failure or clogged filter destroying the engine.
Old 03-30-2013, 07:35 AM
legion609's Avatar
Member #34259
Gas Oil Mixture Ratio Calculator
Old 03-31-2013, 02:57 AM
Frozen6bt's Avatar
Member #10907
I don't get why everyone is so against the OI systems on these quads. I can't seem to find a lot of actual people who have had a failure that resulted in a seized motor just a lot of people saying that it COULD happen.
Oil injection is very common in the 2-stroke snowmachine crowd without issue. I have several snowmachines that are in the 15-20yo range that still use the factory OI setup without issue.
What is so wrong with the OI on the quads?
'05 Sportsman 500ho
Glacier plow, Synthetic winch rope, MudLite XLs.
'88 Trail Boss 250r/es
'90 Trail Boss 250
'08 110cc Taotao
We must reject the idea that every time a law's broken, society is guilty rather than the lawbreaker. It is time to restore the American precept that each individual is accountable for his actions. ~Ronald Reagan
Old 04-06-2013, 01:50 PM
Thomasj's Avatar
Member #7117
Im not sure how they work on sleds, but Ive had them fail on dirt bikes and ATVs. They were all Japanese engines though. They are notorious to fail on the Yamaha blasters and tri motos. It also ended the life of an old TS250 I had.
Premix is FAR better for engine life as well as power production.
Old 04-08-2013, 06:07 PM
777att's Avatar
Member #34215
I deleted mine from fear that it wouldn't be able to keep up. I have too much invested in my machine for a simple failure like this to ruin it. Also, getting rid of the second leg of the throttle cable gave me a little better throttle response and since I ran snorkels up the center I was left looking for a place to mount my reservoir. HOWEVER, I encourage anyone running a fairly stock setup to keep it because they ARE reliable on these machines.
'14 scrambler XP 1000
Catvos 6"
RockCrusher portals
35.5" BKTs on 18 M26 vibes
Turner Eagle Axles
Triangle Snorkel Kit
QSC Clutch Kit
Cecco Braces
Oracle blue halos
JL 6.5 marine speakers and Amp in custom glass box
Custom rear rack and Grille
'96 Sportsman 400L
Bored .60 over, ported w/ Wiseco piston
12.5:1 head
VFORCE3 reed cage w/ carbon fiber reeds
AAEN torquer pipe
EPI Clutch kit
Flywheel lightened 12 ounces
Bored carb., intake and exhaust flange
Marshall Racing chains
Sunstar/ custom sprockets
HPD Oil injection block off
K&N filter
4 alpine 6.5" in fiberglass boxes
2" High Lifter kit
3" extended swing arm
30" silverbacks with black HD3's
2" front spacers 4" rear
Snorkeled
Blue LEDs
11 Ranger XP
8" on 32" silverbacks
Rhino Axles
Old 04-08-2013, 06:57 PM
dwhst9's Avatar
Member #11907
Send a message via AIM to dwhst9 Send a message via Yahoo to dwhst9
I had too much $$$ into my 400 porting, etc to risk an oil injection failure, so I eliminated mine as well.
Also, if you eliminate the oil injection, make sure you get a new throttle cable. The OEM cable has a splitter on it and it can get jammed when not connected to the oil injection and cause the throttle to stick.
Ritter Cycle has them for $19.99.
1996 polaris xplorer changing.over to premix gas
1996 sportman 400 oil bypass
400l oil system fail
95 400 polaris xplorer oil pump
bypass 2 cycle oil injection pump
bypass oil pump polaris 400 atv
bypass the oil injector pump on my 250 ploairs atv
can i eliminate the oil injection pump on my 1996 polaris ultra
how to bypass oil injection on my polaris 400 2 stroke
how to bypass oil injection pump on two stroke
how to check oil injector on 2 stroke atv
removing automatic oiler from polaris xplorer
oil injection pump frony83 ATV Repair and Maintenance 4 05-19-2015 10:37 AM
Abernathy's Cycle terb Polaris XP 1 08-16-2011 07:25 PM
2 cycle oil not being consumed kerchie1 Polaris XP 1 04-15-2011 01:35 PM
VES Gold 2 Cycle Oil Punker ATV Repair and Maintenance 0 04-02-2011 06:20 PM
