Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > Polaris ATV How-Tos
Polaris ATV How-Tos Polaris ATV How-Tos, Guides, FAQs put together by the PolarisATVForums.com membership.
  #31 (permalink)
Old 05-31-2012, 08:22 AM
antoniodef's Avatar
Member #11247
That is where I am from. I will have to check it out the next time I drive that way. Thanks.
Sent from my SCH-I510 using Tapatalk 2
2013 Sportsman 500 H.O. - Guru brush guard, 26" Big Horns, RDC 1/4" spacers, Viper Max 2500lb winch, EPI HD front springs
2011 Sportsman 500 H.O. - Guru brush guard, 26" Big Horns, RDC 1/4" spacers, gutted muffler, Polaris 2500, Polaris HD front springs, Polaris heated grips, Glacier III 60" plow, Quadovator reverse mod, 3 headlight mod, Polaris rear rack extender, rear L&R cargo box, HIDs SOLD
2011 Trail Boss - HIDs SOLD
  #32 (permalink)
Old 05-31-2012, 08:37 AM
Mudd Slinger's Avatar
Member #9889
I'm from the same area. How did your muffler mod work for you?
  #33 (permalink)
Old 05-31-2012, 12:34 PM
antoniodef's Avatar
Member #11247
It rocks! A member here that I ride with sometimes did it for me. Sounds great, looks good and gives a small power increase.
I was showing it to my older brother whose house I am staying at right now while riding up north and he couldn't believe how good the welds were. Unless you know what stock looks like, you would never know it was gutted and welded. Which is a good thing, because it is nothing to see DNR and forestry daily as you drive through town. They just had a huge forest fire a few weeks ago here, so I'm not trying to upset the locals :-)
  #34 (permalink)
Old 06-01-2012, 03:00 AM
Member #9889
I would like to have that done to my 700. I had an aftermarket muffler on my 700 and it woke it up. I couldnt believe the difference. However, it would over heat my machine. Can you shoot me an Email at macdonaldj@oakgov.com?
  #35 (permalink)
Old 04-30-2013, 05:46 PM
thundermountainatv's Avatar
Member #8635
Thanks for the drawings, I am going to run XP850 wheels on a Polaris RZR and need to make a spacer to get past the centering ring. If anyone is looking for real long studs they can be found at Superatv....
Robert
  #36 (permalink)
Old 05-01-2013, 05:32 AM
PolarisRich's Avatar
Member #7183
Robert
Just remember to make the stud holes .030 or 30 thousandths larger than the spec that I have in the CAD diagram!
2005 Polaris Sportsman 500 HO
26" Mudlite XL's, Clutch Kit, 3 Headlight Mod, 1/4" Front Wheel Spacers, 1" Front Spring Spacers, Uni Filter, Heated Grips, 12V Electrical Accessory Panel, Etrex GPS Handlebar Mount and hardwire, Passenger Seat with Cargo, Horn, Snorkeled Vent Tubes, Mossy Oak Graphic Vinyl Wrap, 2500 Runva Winch, ShockPro's Camo Shock Covers
  #37 (permalink)
Old 05-01-2013, 02:33 PM
Member #8635
RZR studs are 3/8" ... I'm thinking they are big enough if I drill them in the right spot....
1/2 wheel spacer for polaris
1/4 rbc spacers
1/4 rbc spacers#gsc.tab
4/156 polaris wheel spacers#gsc.tab
does the 9 mudlite itp tires rub on the front of my 2005 polaris sportsman 500
how to make spacers
how to make wheel spacers
how to make wheel spacers for atv
polaris 1/4 wheel spacer
polaris ranger wheel spacers 1/4
polaris sportsman 500 wheel spacers
polaris wheel spacers 1/2
rbc spacers
rbc wheel spacers
would it be dangerous to use washers for wheelspacers on my polaris sportsmann
wheel spacers?? polarisinnepa ATV Wheels & Tires 14 03-16-2013 05:27 PM
wheel spacers sugarsand007 Polaris Phoenix 0 11-22-2011 11:37 AM
do i need a lift and spacers to make 27 inch tires fit on stock 2011 sportsman 500? solid_crimson ATV Wheels & Tires 2 03-24-2011 05:56 AM
1-1/2" wheel spacers mechanike ATV Parts for Sale 6 02-02-2011 04:18 AM
F/S: Wheel Spacers (never used) 1" 4/156 Front ronsfun96gt ATV Parts for Sale 0 10-25-2009 06:35 PM
