Entering and Using the Speedometer Diagnostic Mode - Polaris ATV Forum
Polaris ATV How-Tos Polaris ATV How-Tos, Guides, FAQs put together by the PolarisATVForums.com membership.
post #1 of 14 (permalink) Old 04-04-2012, 04:20 PM Thread Starter
AKStew's Avatar
You can use the speedometer diagnostic mode to check/reset several indicators, icluding the service interval light (that little wrench you wish would go away but don't know how to reset).
A couple things to know: First, the wrench displays as long as you are in diagnostic mode. Second, THE DIAGNOSTIC MODE REQUIRES THE TRANSMISSION TO BE IN NEUTRAL. If the speedo isn't displaying an "N" in normal mode, then the speedo can't tell if the machine is in the right gear. This will cause the diagnostic mode to not come up when you turn the key on. It also means you will have to check these circuits the old fashioned way.
1. Turn key off for 10 seconds. Place the gear lever in the Neutral position and set your parking brake.
2. Hold Reverse Override button in while turning key on (don't start the engine). You can let it go after the key is on.
3. First you should briefly see a screen that displays the software version loaded on the ECU then it will move to Screen 1. If you use the Reverse Override button it will scroll through the diagnostic screens just like when you are selecting the tach, odo, & hours in normal mode.
Screen 1 = Battery Voltage
Screen 2 = RPM (will indicate "0" unless you started the engine upon entering diagnostic mode, which is OK to do).
Screen 3 = AWD Diagnostics. Tells you whether there is power going to the AWD coil when you move the switch.
Screen 4 = Gear Circuit Diagnostics. Since you are in neutral, the initial value should be screen that brings up the "N" gear indication and the number 158, or close to it. This screen is telling you how much resistance in ohms the gear indicator switch has for a given gear. Move the shift lever to each gear and the corresponding letter and resistance value should pop up as you land on each gear.
P = 23
R = 75
N = 158
L = 297
H = 628
The speedo translates these values into a gear indication on the LCD. The manual says a 10-20% variation is OK. If any of the indications are 0 it could be wiring or the switch. If there is a value other than 0 and out of spec then you need a new switch. It's an easy 5 minute job but the switch is a bit pricey. Also, the speedo controls the AWD engagement. If your speedo isn't showing a "L" or "H" then your AWD isn't engaging in that range. The workaround in a pinch is to hold the Reverse Override button when you need AWD in the forward ranges. That's only in the forward ranges. AWD still wont work in R if the speedo wont display the R.
Screen 5 = Programmable Service Interval Setting. Resets the wrench light. To reset it or to set it to a different interval, hold the Reverse Override button in until the wrench flashes and release it. Use the button to set it to the deisred interval. To exit just wait until the wrench light stops flashing. To disable it, hold the button in for 7 seconds until the word "OFF" appears.
Screen 6 = Miles/Kilometers Toggle. Hold the button in until the letters flash. Use the button to select the desired reading. Wait until the wrench stops flashing and it is set.
2011 Sportsman 500 HO Touring: Polaris 3500 lb. Winch, Kimpex Adventure XL Trunk, 7" Passenger Foot Risers, UNI Foam Filter
2006 Sportsman 500 X2 EFI: Superwinch Terra 25 w/Synthetic Rope, Kolpin 4 gal Gas Pack, 3" Passenger Foot Risers, 3-Headlight Mod, K&N Filter
SOLD 2010 Sportsman 300: Polaris 2500 lb. Winch, Kolpin Rear Seat (for the dog), UNI Foam Filter
SOLD 2006 Sportsman 700 Twin EFI: 27" Mud-Lite XTR, Superwinch Terra 35 w/Synthetic Rope, Polaris HD Front Springs, OEM Front Bumper Guard, WES Rear Seat, Kimpex Fender Guards w/Footpegs, 3-Headlight Mod, K&N Filter, Symtec Heated Grips
AKStew is offline
post #2 of 14 (permalink) Old 04-04-2012, 04:48 PM
dbmachine's Avatar
Is this for the value line of sportsman or the xp line of sportsmans
dbmachine is offline
post #3 of 14 (permalink) Old 04-05-2012, 12:22 AM Thread Starter
AKStew's Avatar
I know it works for the value line but I'm not familiar with the XP.
Stew
AKStew is offline
post #4 of 14 (permalink) Old 04-05-2012, 04:40 AM
SMP63's Avatar
Good write up & explanasion Stew!!!!!!!!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
SMP63 is offline
post #5 of 14 (permalink) Old 04-27-2012, 05:34 PM
Scrambler2Sportsman's Avatar
So here are my values and from what I understand I'm going to need a new switch
P 23
R 73
N 153
L 236
H 338
From checking the switch the awd seems to get power to the coil. Now I have not checked to see if it's engaging
His ~ 2013-Scrambler XP - Painted Polaris Grille Guard ~ Polaris Lock and Ride Box ~ ODI Rouge Grips ~ MSA M12 Diesel Gloss Black Wheels ~ 28x9x14 Swamplites(Front) ~ 28x11x14 Swamplites(Rear)
Hers ~ 2005 sportsman 800 EFI - Polaris Winch - 27" Outlaw MST's ~ Raceline Monster Wheels ~ FOR SALE
Scrambler2Sportsman is offline
post #6 of 14 (permalink) Old 04-27-2012, 05:36 PM
Also the low range indicator always stays on when in hi currently right now
post #7 of 14 (permalink) Old 04-27-2012, 06:06 PM
Great job Stew! Thanks for adding to this section
blueline15 is offline
post #8 of 14 (permalink) Old 04-27-2012, 06:31 PM
KICKER431's Avatar
Does that mean Stew is finally gonna get somethign stickied?
completely stock FOR NOW
26" Maxxis Bighorn 2.0
KICKER431 is offline
post #9 of 14 (permalink) Old 04-29-2012, 03:41 PM
drewpul's Avatar
On a polaris ATP, is there a way to see if the "Turf Mode" is working. I see an icon for 4x4 when im in diag mode. Is there supposed to be one for turf?
drewpul is offline
post #10 of 14 (permalink) Old 04-30-2012, 12:00 PM Thread Starter
AKStew's Avatar
I'm guessing not. My X2 has turf mode and it doesn't check it.
You can do a crude check by turning the key on (engine off) and cycling the turf mode switch. You should hear the solenoid clicking with each flip of the switch. If not, then you need to start checking continuity.
Stew
AKStew is offline
Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > Polaris ATV How-Tos
Diagnostic mode for a 07 800 chuckinnc Polaris Sportsman 2 10-20-2014 07:07 PM
Entering ATV shifter box- help. Neptugian ATV Repair and Maintenance 8 09-23-2011 11:39 AM
How accurate is the diagnostic mode? grub ATV Repair and Maintenance 2 05-26-2011 08:28 PM
Does a 02 Sportsman have a Diagnostic Mode? CWright ATV Repair and Maintenance 6 11-03-2010 07:42 AM
Trouble Entering Diagnostic Mode 2008 700X2 mtuser2007 ATV Repair and Maintenance 6 09-14-2010 01:15 PM
