01 sportsman front outer cv joint removal from axle - Polaris ATV Forum
Polaris ATV How-Tos Polaris ATV How-Tos, Guides, FAQs put together by the PolarisATVForums.com membership.
post #1 of 13 (permalink) Old 05-29-2012, 09:01 PM Thread Starter
eye_guysd's Avatar
OK,
found this site and hope its going to be as informative as other I have found for sleds/boats etc... anyway,, here goes.
I have a 2001 sportsman 500 and need to replace the front/outer cv boot. I have pretty much everything done up to the point of getting the cv joint off the axle to get the new boot on. And here is my problem,[I] I can't find the SNAP RING to expand to get the joint to slide off the splines[/I]. I cleaned alot of the grease out and can't find a recessed spot in the cv joint that the snap ring would fit in? Do I need to remove any balls and ball holders/cage or whatever?? Do all polaris have snap rings, or do I tap it off the axle..
Thats it guys/gals save the day for me,,,
as I am running out of bud lights... lol.
eye_guysd is offline
post #2 of 13 (permalink) Old 05-29-2012, 09:58 PM
Bruce! is offline
post #3 of 13 (permalink) Old 05-29-2012, 10:34 PM
mowreyj's Avatar
Just give it a good jerk it will come off replace boot the tricky part is getting it lined back up with all the grease in there pop it in and bolt it back up helps too if you take the tie rod off
02 500 sportsman x
warn 2500 front-back winch
2 inch lift
heated grips
customized muffler
heat wrap pipe
2 halogen beams
tamarack passenger pegs
HERS
99 350 Big Bear
14" SS wheels
ITP baja cross 26" tires
Kolpin fr.-Back bags
thumb throttle extender
custom exhaust
3" additional lights on front
mowreyj is offline
post #4 of 13 (permalink) Old 05-30-2012, 08:57 AM
KICKER431's Avatar
Here is my tip: When in doubt, check the exploded parts diagram on any parts website. I go to cheapcycleparts.com. Here is the link for what you are looking for:
CV JOINT - BTB - A01CH50AA Polaris SPORTSMAN 500 HO (A01CH50AA) 2001 OEM Parts - Cheap Cycle Parts
It shows a circlip, which isn't an eared snapring. It is instead a compression spring that keeps a little tension on and can be overcome with a few stiff whacks from a hammer of some sort.
Happy wrenching (and whacking)(the cv joint tha is)
completely stock FOR NOW
26" Maxxis Bighorn 2.0
KICKER431 is offline
post #5 of 13 (permalink) Old 05-30-2012, 10:08 AM
jandj's Avatar
Im having the same problem today! Whacking and whacking and it doesnt budge. Tough little retaining spring. Must try a bigger hammer, the 5# dead blow isnt working very well.
  • 08 500 EFI
  • LandR rear box
  • 2500#Milemarker
  • AME heated grips
  • UNI filter
  • Stock 26"PXT wheels
  • 3 headlight mod
  • 08 420Rancher ES
  • 2500# Mile Marker
  • ATV TECH rear bag
  • AME heated grips
  • UNI filter
  • 25"Power grips
jandj is offline
post #6 of 13 (permalink) Old 05-30-2012, 11:19 AM
mowreyj's Avatar
I think you can just jerk n it will come off
I changed one a while back and took a little muscle the hardest part for me was getting the splines lined up and popping it back in but was not too hard just be sure you have it lined up good when putting axle into CV hope this helps
02 500 sportsman x
2 inch lift
heated grips
customized muffler
heat wrap pipe
2 halogen beams
HERS
99 350 Big Bear
14" SS wheels
custom exhaust
mowreyj is offline
post #7 of 13 (permalink) Old 05-31-2012, 05:44 AM
fmartin_gila's Avatar
CAREFULLY READ THE POSTS - some of you are talking about different ends of the axles. The inner joint has the ring to retain it in the differential - the outer end just slides on and off as jmowery stated, his is the same as mine and it will just slide on and off.
Fred
fmartin_gila is offline
post #8 of 13 (permalink) Old 05-31-2012, 06:40 AM
KICKER431's Avatar
Actually on an '01 the front inner joint is a u-joint. Not a cv joint. So he can only be talking about removing the outer cv joint. Not sure what year they changed that but my '04 has front inner u-joints and my '07 has front inner cv-joints.
post #9 of 13 (permalink) Old 05-31-2012, 06:58 PM Thread Starter
eye_guysd's Avatar
update
All right, thanks for the advice.
For the most part the information given was correct. Two quick pops with a soft mallet and it popped right off.
also the 01' does have a U-joint style inner joint. Now how do I pop it back on... same process just in reverse???
thanks again guys,,, I'll spend much more time on here..
post #10 of 13 (permalink) Old 05-31-2012, 07:26 PM
KICKER431's Avatar
Happy to help Eye-Guy. I have been helped innumerable times by the forum hive-mind. It has saved me tons of money and because of the friendly folks here, neither of my machines has ever been "in the shop." So I try to help others when it is something I have some knowledge about.
Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > Polaris ATV How-Tos
Separating front axle from CV joint on '98 Sportsman 500 redneckff42 ATV Repair and Maintenance 2 05-08-2013 10:29 PM
U-joint style rear axle removal Diesel Polaris Sportsman 6 08-23-2012 02:02 PM
LF front outer cv joint for 07 and up sportsman cowboy_cadillac ATV Parts Wanted 2 12-27-2011 02:20 PM
05 sportsman front lower ball joint removal mv7 ATV Brakes & Suspension 3 12-25-2011 06:03 AM
2009 Sportsman 800 front axle removal idler8 ATV Repair and Maintenance 0 09-18-2011 11:56 AM
