01-23-2011, 05:46 PM
Member #11201
Best clutch
I have a 2005 Sportsman 800 that I just bought and it has 6 hours on it. I am putting 27 in. ITP mud lites or XTR's. maybe even GBC Dirt Tamers. WHO has the best clutch for a hunting / work / play environment. Sea level to 6600 ft elevation. Can anyone help?
01-23-2011, 07:46 PM
01-24-2011, 01:39 AM
I don't know if they are the best, but I just went for a EPI kit for sport Utility w/bigger tires. I haven't installed yet, it will go in over this winter. I making a secondary compression tool first.
But most kits go from 0-3000' above 3000' is a different kit, so finding one that will do ALL is likely not a reality. You may need to narrow it down some.
Heel Clicker, Dalton and EPI all make kits guys like.
Good luck,
01-24-2011, 09:12 AM
Member #11201
Thanks for your input. I have actually contacted some of those manufacturers and I believe that the HeelClicker is the best one for my use. It has a broad adjustment range and I liked the fact that Polaris racing is using them.
01-24-2011, 09:45 PM
Member #3805
Welcome. i would say go for oem.. still no other brands beats it unless performance clutches.
08 sportsman 800 best clutch, 2007 polaris 800 clutch problems, best atv clutch for mud, best clutch for a polaris sportsman 800, best clutch for polaris, best clutch for polaris 500 with big mud tires, best clutch for polaris sportsman 800, best clutch for sportsman 800, best hunting atv 2011, best hunting atv forums, best polaris atv clutch, best polaris atv for hunting, best polaris clutch, best polaris sportsman clutch, clutch for polaris sportsman 800 with big mud tires, clutch kit for sportsman 800 for mudding, polaris atv clutch sea lrvel altitude, polaris sportsman 800 clutch best for mud, which best clutch for polaris sportman, which clutch is best for my sportsman 800
