Go Back   Polaris ATV Forum > Polaris ATV Forums > Polaris ATV Polls
Polaris ATV Polls This section contains site related polls or polls related to Polaris ATVs. Only administrators may start topics in this section.
View Poll Results: Which filter do you use?
K&N 75 43.60%
UNI 36 20.93%
No Toil 2 1.16%
Twin Air 5 2.91%
OEM 51 29.65%
other 3 1.74%
Voters: 172. You may not vote on this poll
  #41 (permalink)
Old 02-16-2011, 05:05 AM
papabare's Avatar
papabare
Guest
Member #
Posts: n/a
I prefer the dual layer foam filters and I make my own prefilters.
If you can see through the open cotton style filters like K&N, then the dust goes straight through them and into your motor!
  #42 (permalink)
Old 02-16-2011, 02:13 PM
Dbez1's Avatar
Member #10159
How do you make your own prefilters?
  #43 (permalink)
Old 02-16-2011, 02:55 PM
jscantland's Avatar
Member #8582
Cool
Knee-high panty hose doubled over a couple times. I've used this hilbilly method in desperate times, figured it was better than nothin.
2008 Scrambler 500
Aaen Torquer exhaust
K&N
Oxlite a-arm guards
DG bumper
rear rack
grip warmers
1999 400EX
2002 Scrambler 90
  #44 (permalink)
Old 02-17-2011, 10:03 AM
papabare's Avatar
papabare
Guest
Member #
Posts: n/a
Prefilters
I purchased the 100 micron material and sew them together from a pattern that I make.
I also make my own plow lift straps (1 ton test) so that I don't wear out my Amsteel lines.
aif that deal with firearms
does polaris make there own air filters
foam filter vs. stock polaris paper filter
foam vs cotton filters
holeshot foam filter
k&n oil filter vs. polaris oem
oem polaris air filter vs. twin air oiled foam
paper or foam filter for polaris
polaris paper air filter
stock paper filter or foam uni polaris sportsman
twin air vs no-toil filter
twin air vs stock atv air filter
twinair filters for polaris 500 atv
uni air filter vs oem air filter atv
uni filter versus no toil
uni filter vs no toil
uni filters vs twin air
uni vs. twin air filters for polaris atvs
use polaris prefilter on no- toil
what if i use the wrong air filter in a polaris?
fuel filter crtcn2112 Polaris Sportsman 6 06-08-2011 04:00 PM
XP Oil Filter tool? Mechhell ATV Repair and Maintenance 20 04-27-2010 04:20 PM
What is the correct Oil Filter ??? bama13 ATV Repair and Maintenance 12 03-10-2010 01:56 AM
air filter replacement. pafree ATV Repair and Maintenance 5 02-16-2010 11:54 AM
Engine Oil Filter heff560 ATV Repair and Maintenance 2 04-22-2009 05:17 PM
