Go Back   Polaris ATV Forum > Polaris ATV Forums > Polaris ATV Polls
Polaris ATV Polls This section contains site related polls or polls related to Polaris ATVs. Only administrators may start topics in this section.
Old 10-11-2010, 06:07 PM
pearbob's Avatar
Member #8105
Overheating
I just replaced the fan motor and the thermo switch and it is still overheating.
I can jump at the thermo switch and turn the fan on but it will NOT come on by it self. Does anyone have any idea's ???
Old 10-11-2010, 06:27 PM
ZEUS's Avatar
Member #7484
Do you check the radiator outside and inside ? Mayor be its stuck with Mud.
Polaris Sportsman 850 XP Camo 2010 - The Best
Honda Rancher 420 4x4 AT ES 2009 - The best MPG !!
Old 10-11-2010, 06:41 PM
jshields's Avatar
Member #6457
If the fan works hotwired and the coolant is flowing through your radiator (you should be able to see the fluid move throught he clear tube). The issue may not be either of those. There is a auto-reseting breaker that sometimes does not reset. I had this happen on my new machine and all it was still under warranty. There should be a matchbox size device in the wiring harness near the back of your battery. Check to make sure the connection is being made and maybe disconnect it and reconnect it to see if it will reset it. If you machine is under warranty i would reccomend taking it in and letting them do it so that you have a record of issue. If this is the issue your machine should not be overheating, its just the "HOT" light messing up because of the breaker (but get it checked asap just to make sure). Repost here and let us know what you find.
Old 10-12-2010, 06:12 AM
pearbob's Avatar
Member #8105
Overheating 1999 Diesel
I've had the radiator cleaned and repaired. But I'll check that box back by the batteries. THANKS for your help.
Old 10-12-2010, 12:29 PM
jshields's Avatar
Member #6457
Hey when you post with issues, i would also list year, make and model with any mods that you may have added. It will help people because some issues are known with some makes/models and could bring in more of a specific issue. Let me know what you find out...
Old 01-14-2011, 08:09 PM
john1's Avatar
Member #11045
it could be your ecu unit
Old 01-19-2011, 05:00 PM
elmerkit's Avatar
Member #3805
Check your thermostat it could be stuck.
850 polaris overheating
atv over heating
atv overheating
overheating atv
overheating polaris atv
polaris 850 over heating
polaris 850 overheating
polaris atv overheating
500 HO overheating 02f250fx4 Polaris Sportsman 9 09-14-2010 04:41 PM
03 700 overheating mudbug Polaris Sportsman 9 06-30-2010 05:32 PM
Overheating 700 bbbj ATV General Discussion 11 02-13-2010 10:10 AM
Overheating 700 bbbj ATV Repair and Maintenance 5 08-17-2009 09:57 AM
'01 500 HO overheating knute13 Polaris Sportsman 5 06-27-2009 08:27 AM
