Fitting another model muffler to '00-'02 Magnum? - Polaris ATV Forum
post #1 of 6 (permalink) Old 12-13-2016, 10:10 AM Thread Starter
RacerP's Avatar
So I need to replace my muffler, want something factory.
The '00-'02 Magnum muffler have the unique 12:00 and 6:00 mounts.
Everything on eBay is $80+ and up.
Wondering if anyone has tried retrofitting say, a Sportsman muffler from another year or model, plenty of those on eBay that are way cheaper.
RacerP is offline
post #2 of 6 (permalink) Old 12-13-2016, 06:29 PM
stave7119's Avatar
I looked at that when I put the 330 engine in my MOSE Magnum. There was not exhaust with the machine when I got it and I had gotten the exhaust for the 330. Problem I found was that the mid pipe is different to so not only would I have to manufacture new mounts for the muffler, but it would have to move forward to match up with the muffler. That would have put it too far forward for the plastic to fit.
Another consideration is that the exhaust is...well tuned for lack of a better term....for the engine. The right amount of silencing but leaving the best performance. Not sure a later sportsman would fit that bill. You don't say what size magnum you have but if you get a muffler of the same size displacement it might work.
My 2Cents, it isn't worth the effort for the little $ savings
1st Machine
2001 Magnum 325 with a blown engine; rebuilt 2004. Broke timeing chain 2016 rebuilt again and still running. Warn winch and Moose 60" plow
Wife's machine:
2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. 12x7 front, 12x8 rear, QSC Clutch Kit
My Trail Machine:
2004 Sportsman 600 Twin, 25" RipSaw Tires on stock steel wheels, Moose rear box
Completed Project machine:
2001 Magnum 325 MOSE with a blown engine. Transplanted a 2005 Magnum 330 engine. Committed suicide on the trail Oct 2016. Spun Rod Bearing after oild cooler line failure. Rebuilding Engine.
stave7119 is offline
post #3 of 6 (permalink) Old 12-15-2016, 02:12 PM Thread Starter
RacerP's Avatar
Stave,
Thanks for the reply. It's a 325. Odd thing is, our muffler was fitted to everything from the 325 to the 500. Other alternative is the Kimpex Exsound??
SERIES 10 PPS PTV 4X4 EXHAUST SYSTEM - C10CD50AA (4977417741A11)
2002 ATV 325 MAGNUM 2X4 HDS EXHAUST SYSTEM - A02CB32AA/AB/FC (4970107010A12)
2002 ATV MAGNUM 325 2X4 EXHAUST SYSTEM - A02CB32AA/AB/FC (4970107010A12)
2002 ATV MAGNUM 500 2X4 HDS EXHAUST SYSTEM - A02CB50FC (4974857485A10)
2002 ATV 325 MAGNUM 4X4 HDS EXHAUST SYSTEM - A02CD32AA/AB/AC/FB (4970147014B01)
2002 ATV MAGNUM 325 4X4 EXHAUST SYSTEM - A02CD32AA/AB/AC/FB (4970147014B01)
2002 ATV MAGNUM 325 4X4 FREEDOM EXHAUST SYSTEM - A02CD32AA/AB/AC/FB (4970147014B01)
2002 ATV 500 MAGNUM VL HDS EXHAUST SYSTEM - A02CD50AA/AB/FB (4970197019A11)
2002 ATV MAGNUM 500 EXHAUST SYSTEM - A02CD50AA/AB/FB (4970197019A11)
2002 ATV MAGNUM 500 RMK EXHAUST SYSTEM - A02CD50AA/AB/FB (4970197019A11)
2002 ATV XPEDITION 325 EXHAUST SYSTEM - A02CK32AA (4970287028A11)
2002 ATV XPEDITION 425 EXHAUST SYSTEM - A02CK42AA/AB (4970327032A10)
2002 PPS ATV PRO 500 4X4 PPS EXHAUST SYSTEM - C02CD50AC (4972407240A11)
2001 ATV 325 MAGNUM 2X4 HDS EXHAUST SYSTEM - A01CB32AA (4963966396A012)
2001 ATV MAGNUM 325 2X4 EXHAUST SYSTEM - A01CB32AA (4963966396A012)
2001 ATV 325 MAGNUM 4X4 HDS EXHAUST SYSTEM - A01CD32AA (4964026402A010)
2001 ATV MAGNUM 325 4X4 EXHAUST SYSTEM - A01CD32AA (4964026402A010)
2001 ATV MAGNUM 325 4X4 MOSE EXHAUST SYSTEM - A01CD32AA (4964026402A010)
2001 ATV 500 MAGNUM 500 HDS EXHAUST SYSTEM - A01CD50AA (4964196419A010)
2001 ATV MAGNUM 500 EXHAUST SYSTEM - A01CD50AA (4964196419A010)
2001 ATV XPEDITION 325 EXHAUST SYSTEM - A01CK32AA (4964086408A011)
2001 ATV XPEDITION 425 EXHAUST SYSTEM - A01CK42AA (4964136413A010)
2000 ATV 325 MAGNUM 2X4 HDS EXHAUST SYSTEM - A00CB32AA (4949354935B001)
2000 ATV MAGNUM 325 2X4 EXHAUST SYSTEM - A00CB32AA (4949354935B001)
2000 ATV 325 MAGNUM 4X4 HDS EXHAUST SYSTEM - A00CD32AA (4949404940A013)
2000 ATV 325 MAGNUM 4X4 HDS II EXHAUST SYSTEM - A00CD32AA (4949404940A013)
2000 ATV MAGNUM 325 4X4 EXHAUST SYSTEM - A00CD32AA (4949404940A013)
2000 ATV 500 MAGNUM 4X4, HDS EXHAUST SYSTEM - A00CD50AA (4954885488A012)
2000 ATV 500 MAGNUM 4X4, HDS II EXHAUST SYSTEM - A00CD50AA (4954885488A012)
2000 ATV MAGNUM 500 EXHAUST SYSTEM - A00CD50AA (4954885488A012)
2000 ATV MAGNUM 500 EB EXHAUST SYSTEM - A00CD50AA (4954885488A012)
2000 ATV XPEDITION 325 EXHAUST SYSTEM - A00CK32AA (4954895489A011)
RacerP is offline
post #4 of 6 (permalink) Old 12-15-2016, 05:58 PM
stave7119's Avatar
So anything from a 325 to a 500 should work performance wise. And a muffler from any of those models should work with the exhaust pipe and be a bolt on. That's good news! I haven't looked at the Kimpex piece, but I know the company has been around for a long time. If they have something for the model, I would trust them.
1st Machine
Wife's machine:
My Trail Machine:
post #5 of 6 (permalink) Old 01-11-2017, 04:10 AM
ccuckie51's Avatar
Exclamation muffler for magnum
was wondering if you ever found one to fit and if so please share what and were you got it
thank you
ccuckie51 is offline
post #6 of 6 (permalink) Old 01-11-2017, 05:06 AM Thread Starter
RacerP's Avatar
No...I never found an alternative in my price range.
I did though use Craigslist and found a stock muffler from someone parting a machine for $25!
RacerP is offline
Missing a zerk fitting in front prop shaft aflores41 Polaris Sportsman 570 6 09-23-2016 09:38 AM
HPD Pipe and MSA Muffler - Off Trailblazer 250 psczbug ATV Parts for Sale 4 09-07-2016 07:54 AM
identifying model mr157ifhz ATV Repair and Maintenance 9 04-15-2016 04:09 AM
1994 Polaris 400L clutch cover alternatives? bigcheese ATV Repair and Maintenance 2 03-09-2016 12:19 PM
Looking for a Scrambler Muffler dodgerc ATV Parts Wanted 0 02-14-2016 03:21 PM
