Old 01-09-2012, 12:52 PM
CaseIHfarmer's Avatar
Member #22135
Engine Temp Light On
The engine temp light is on in my 325 magnum as soon as I start it even when it's cold and it stays on the entire time. The wheeler seems to be running fine other than that though. Any help would be greatly appreciated.
Old 01-09-2012, 01:24 PM
And welcome to the board!
Old 01-10-2012, 04:11 PM
adamcr80123's Avatar
Member #18654
If the fan is running, turn key on and see if it starts up, dont worry about it. Thats what i did. if you want to worry about it, it is most likely the thermistor on the top of the rad.
Old 02-08-2012, 09:45 PM
bakada's Avatar
Member #2821
My magnum 325 has the same problem. The temp light comes on as soon as you start it. It is weak and seems to get brighter as you rev the motor. In the sun light it is hard to see. It is not as bright as the low gear light. I have never heard my fan come on but I put 12 volts to it and it ran. I'm thinking I might have a bad switch which is allowing a weak short and causing my weak light that brightens slightly with engine RPM.
Old 02-08-2012, 11:04 PM
Member #18654
for a light to brighten with more rpm your likely looking at a bad battery, battery connection or charging system. As for the fan not coming on you could have an issue there as well. Most of the time the thermistor dies and the fan is always on.
Old 02-09-2012, 08:41 AM
bakada's Avatar
Member #2821
Thanks for the response. The battery is new. I will check for tight connections. The head lights and brake light all seem to work good. The only dash light that doesn't come on and off like they are supposed to is the temp light and as mentioned it is not very bright but does brighten slightly when the rpms come up. I have never heard the fan but I guess that doesn't mean that it isn't coming on and I'm just missing it. My daughter drives it mostly and we don't have any extremely hot weather up here. Maybe its just not getting warm enough to need the fan. I need to look closer at the wires and connections and make sure I don't have a short some where giving a little juice to that light all the time. I hate electrical gremlins.
Old 02-09-2012, 05:26 PM
hduc2005's Avatar
Member #21883
Check the coolant level in the radiator if it is low add coolant
Old 02-09-2012, 05:38 PM
bakada's Avatar
Member #2821
Magnum 325s don't have coolant. They are air cooled and have an oil cooler. The fan is supposed to kick on to cool the oil if it gets to hot.
2011 polaris sportsman 500 ho hot thermister issues
engine light on polaris scrambler
engine temp light on
oil light polaris outlaw
outlaw temp light
polaris 325 magnum temp light
polaris outlaw temperature light
polaris scrambler 500 for sale
polaris scrambler hot oil light
polaris scrambler temp light
polaris sportsman 500 fan was running temp light came on
polaris sportsman 700 thermistor
polaris sportsman check coolant level cold or hot?
polaris sportsman temp light
polaris temperature light on
temp light on polaris magnum on during winter
temp light polaris sportsman
troubleshooting engine temp light polaris 325
yamaha buggy oil temp light on
yerf dog gx150 charging system test
oil temp light always on? PAshadow Polaris Trail Boss 1 10-25-2011 02:46 PM
temp light on cummins666 Polaris Scrambler 3 09-11-2011 06:14 PM
2000 magnum 325 2x4 (temp light) bcarfley Polaris Magnum 6 01-27-2011 03:28 AM
2000 Magnum 325 Temp Light z27651 ATV Repair and Maintenance 7 04-04-2010 08:42 PM
Temp Light marco_wezo Polaris Outlaw 1 03-23-2010 04:14 PM
