12-18-2010, 12:56 PM
Member #9425
Oil change 525
Just finished changing the oil in my 525 Outlaw, what a involved proccess, 1 drain plug, two screens and two filters, got it done though, first oil change so it had some junk in screens, I believe it was the sealant they use between the cases. Cannot believe they reconmend changing every 15 hours.
12-18-2010, 01:20 PM
A very high performance, quick revving motor, with not a lot of engine oil in it. Its one reason why there is two oil filters, so it can go 15 hours between changes. I know guys who have the 525 engine in their supermoto motorcycle and have to change the oil after every race.
12-19-2010, 08:52 PM
Member #7775
I do mine more than every 15 hours, its only 2 quarts. Then the filters are cheap over at Rocky Mt ATV
12-20-2010, 07:43 AM
Member #9425
How much oil are you guys putting back in after a drain and filter change? my manual says 40 ounces, run then check. I did that and the oild was not coming up to the half way mark on the sight glass when warm so I put in about 8 more ounces, now it seems correct, at by how the book says to check it.
12-20-2010, 01:01 PM
Member #7775
I fill it halfway up the sight glass, run it around the block, let it sit for a few minutes and top off as needed.
03-22-2011, 04:24 PM
Member #12430
i put 1.7 quarts in just how the book says, now the oil is only in the bottom quarter portion of the sight glass, i know i put enough in y isnt it showing in the sight glass correctly?
2009 polaris outlaw 525 change oil, 2011 polaris 525 outlaw oil filter, changing the oil in 2009 polaris outlaw, how much motor oil does a polaris outlaw 525 hold, how much oil does polaris outlaw 50 take, how much oil in a polaris outlaw 525, how much oil to put in 08 525 outlaw, how to change oil on a 07 polaris outlaw 525, oil change 07 polaris outlaw, oil change ktm 525 polaris, oil change polaris outlaw 525, oil type for polaris 525 outlaw, outlaw 525 oil change, outlaw 525s oil filter, outlaw engine oil weight, polaris 525 oil change, polaris outlaw 525 oil change, polaris outlaw 525 oil filter, polaris outlaw 525 oil spec, polaris outlaw 525s oil filters
