12-22-2010, 02:23 PM
Member #10353
Outlaw 500 Part at bottom of engine. HELP
I took my 06 Outlaw engine apart and found a watch battery sized item marked 190 sitting at the bottom of my engine. Anyone know what it is or were it goes? Please check pic. Thanks
12-23-2010, 04:46 AM
12-23-2010, 02:36 PM
Its a shim for your valve. Not good. You need to get the head off and figure out what is going on. Do no run this thing until then your you will be rebuilding you top end and bottom end.
If this did no damage to the bottom end, you are very very lucky, as its very expensive to split the cases and rebuild the bottom end
12-23-2010, 04:11 PM
Member #3687
Just looking at it could it be possible that it is part of a thermostat. I don't know alot about the newer machines. Just thinking it might be another possibility? My little wheel is turning in my brain about this now. Post what you find. Thanks
12-24-2010, 02:54 AM
Member #7294
You say you have the engine apart, what is the reason for that? Also welcome to the forum.
12-24-2010, 12:16 PM
Member #7775
Its a valve shim
2008 525 outlaw engine bottom end breakdown, best polaris outlaw motor, how much does it cost to rebuild a polaris outlaw motor, how to rebuild engine polaris 525 outlaw, outlaw 500 tick, outlaw 500 valves, outlaw 525s bottom case, outlaw polaris 500 engine noise, polaris outlaw 500 engine, polaris outlaw 500 engine lower end, polaris outlaw 500 motor, polaris outlaw 500 motor rebuild, polaris outlaw 500 top end rebuild, polaris outlaw 500 valve seal problem, polaris outlaw 500 valve shims, polaris outlaw engine, polaris outlaw engine noise, polaris outlaw motor, rbuild lower end polaris 400, valves 500 outlaw polaris
