Old 12-24-2010, 01:16 PM
ntispdfreak's Avatar
Member #10409
06 Outlaw 500 Won't Idle
I have a 06 Outlaw 500 and it will not idle. I have cleaned the carb it is really hard to start without the throttle all the way open. I have a service manual, but I am not sure where to start. Did a compression test and only came up with 50 psi under its own battery power and 60psi with the battery charger hooked up. I know it has a decompressor system, but do not know how to test. I do not have a leakdown tester per the manual. Help please, problem is very troubling!
Old 12-24-2010, 03:18 PM
terrasmak's Avatar
Member #7775
Send a message via Yahoo to terrasmak
Check the valve clearance
Old 12-24-2010, 04:20 PM
Member #10409
I checked the lash and the Intake side is tighter than .0015 which is supposed to be .006 and the exhaust side is the .010 on one valve and .011 on the other. Obviously I can see that the intake valve is the problem where I am losing my compression. Now my question is why would the space decrease so much? Does the valve stretch to make the lash smaller? I thought it would be the opposite. How extensive is fixing the lash and does a polaris dealer usually carry the shims? Do you have to remove the timing chain in order to change the shims? The manual shows but is not clear if this can be done due to book going through a total breakdown of the engine and by the time I get to the shimming section, the head has already been removed.
Old 12-24-2010, 05:18 PM
Old 12-25-2010, 03:01 PM
terrasmak's Avatar
Member #7775
Yes its important, yes it need to be fixed, the valves stretch and the seat wears down. The dealer should have your shims, if not go to another dealer, just measure and figure out the width of the shim, many bikes take the same shims.
atv won't idle
cleaning carburetor polaris outlaw 525
compression test polaris outlaw 500
how clening carburator outlaw 500
how to adjust carburetor on outlaaw 500
how to clean carburetor on polaris outlaw
how to remov polaris outlaw carb
outlaw 500 chain adjustment
outlaw 525 will not idle
outlaw 525 wont idle
polaris outlaw 500 carb
polaris outlaw 500 carbertarproblems
polaris outlaw 500 compression
polaris outlaw 500 valve adjustment
polaris outlaw 525 carb adjustment
polaris outlaw valve shims
suzuki atv won't idle
valve adjustment polaris outlaw 500
what type of battery does a polaris outlaw 500 take
why wony my polaris idle on its own
How to set idle? ferg_29 Polaris Outlaw 1 06-03-2010 04:44 PM
idle question marsh_huntr Polaris Sportsman 4 05-02-2010 07:36 PM
02 Trailblazer 250 will not idle clayc102 Polaris Trail Blazer 2 05-01-2010 06:47 PM
Will not idle??? ryoung ATV General Discussion 4 02-21-2010 05:09 AM
idle too low or not? pafree ATV Repair and Maintenance 5 02-16-2010 01:24 AM
