Old 02-01-2011, 09:18 AM
ScottieD's Avatar
Member #11607
I bleed green but I bought an Outlaw anyway..
Hi, I was just wondering if any of you could shed some light on the 2005 Polaris Outlaw 525. At least that is what I think it is, although I can't find it on any parts fiche. It might be an 06 I haven't checked the V.I.N. yet. I am a Kawi mechanic and I came across this quad for a very reasonably price. I couldn't pass it up. Anyway the engine case is busted where it meets the stator cover. Supposably the chain came off and smacked it. What I am really needing is information on how similar the various Outlaws are in there crankcases. There are several on ebay, but none are for my paticular model. Are the 500 cases the same as long as it is from a certain year range? Also do they share the same parts as a Predator other than the IRS models? Any info would be appreciated.
Old 02-01-2011, 10:16 AM
antoniodef's Avatar
Member #11247
I am new to the ATV game, but I believe the 525 is actually a KTM motor. And from the spec sheets, it is the only KTM motor in the Polaris line up.
Someone correct me if I am wrong.
2011 Trail Boss - HIDs SOLD
Old 02-01-2011, 10:21 AM
Welcome to the forum. If it is the Outlaw 525, it has to be a 2008 or newer. The Outlaw 525 is actually the KTM motor imported from Austria and stuck in the polaris outlaw frame. As far as side cases go, any side case from a 2008 to newer Outlaw 525 IRS, 525 S, or the 450 MXR should fit.
The outlaw and predator 500 are different machines. The motor is different completely. That is polaris's motor, and so the case would not work.
If you can find a potential case for an Outlaw 525 or Outlaw 450 MXR, i can verify for you whether it will work or not before you buy, but it should all fit, without actually looking.
Old 02-01-2011, 04:19 PM
Old 02-02-2011, 09:04 AM
ScottieD's Avatar
Member #11607
Thanks for the info. I checked the V.I.N. last night and it is a 2006, so that means it is a 500??
Old 02-02-2011, 09:29 AM
Should be yes, if its a 2006. I can verify for you with the VIN, and run it in the polaris dealer site.
Old 02-03-2011, 11:10 AM
ScottieD's Avatar
Member #11607
Definitely, I would like for you to do that. Will your system bring up service records etc? I'll have to go get it and write it down.
Old 02-03-2011, 11:20 AM
Yes, if any warrany work has been done, or if the dealer took the time to add any notes on the service work on the machine, then that will come up as well.
06 outlaw 500 vin
06 polaris outlaw vin location
atv game with outlaw 525
green polaris outlaw
is the motor different polaris predator 500 irs
location of outlaw 525 vin
outlaw 500 stator
outlaw 500 vin
outlaw irs vs predator
polaris 500 outlaw frame
polaris 525 vin no
polaris outlaw how to bleed clutch line
rear brake bleeding polaris outlaw 525s
sup up a polairs outlaw 525
vin location on polaris outlaw
vin tag on polaris outlaw
what type of engine parts do i buy for my polaris outlaw 525?
where is the vin located on a 2006 polaris outlaw
where the vin on an outlaw 525s
where to locate vin number on 2008 polaris outlaw 525
97 magnum headlight green asm WTB snkybuster ATV Parts for Sale 1 12-06-2010 11:27 AM
Scrambler radiator bleed? thebode11 ATV Repair and Maintenance 0 10-15-2010 07:11 AM
Hello from Green Bay, WI nadekeys ATV New Members 17 09-20-2010 04:09 PM
1994 400L 4x4 Brake Bleed issues Nondem ATV Brakes & Suspension 7 06-15-2010 10:52 AM
how to bleed brakes on a polaris scrambler triefff ATV Repair and Maintenance 3 04-04-2010 08:05 PM
