Old 02-13-2011, 08:41 PM
sskip75's Avatar
Member #6103
450 mxr to 525s
I'm looking for info on changing my 08 450 to a 525. I have done a little research and the only things I can find are changing cylinder, piston, and slight adjustments in carb. I have a manual and was able to find some info there, and have talked to local dealer with out much luck. Has anyone heard of this being done? Or, does anyone know how to accomplish this? Any help would be greatly appreciated.
Old 02-26-2011, 06:38 PM
OUTLAWMUDDER's Avatar
Member #12375
Sounds right. The ktm 450 and 525 are practically the same motor just with a different bore and cylinder. All you should have to do is buy a 525 cylinder and piston, or have your cylinder bored, and buy a 525 piston. The 450 has a 89mm bore, and the 525 has a 95mm bore. Then of course you will have to jet accordingly, for your increase in displacement. Good luck with everything.
2008 Outlaw 525s
FMF 4.1 Slip On
Wiseco 12.5:1
Rath racing intake
Old 02-26-2011, 07:51 PM
CB BLR's Avatar
Member #12304
Why not just turn your 450 into a 540 or 570 and be done?
It only takes a different sleeve which is available from KTM or Thumper racing to get to these displacements.
Chris
Old 02-27-2011, 05:04 AM
sskip75's Avatar
Member #6103
I recently spoke with Daryl Rath of Rath racing, and he brought up the 540 kit. I did not know there was a big bore kit for this bike. I'm going to pick one up but need to get some more info about the reliability. I can do the change but do not want to rebuild after every ride. We only get to ride about 4 times a year and put about 150 miles per ride on. So I guess my next step is to research the reliability issue.
2008 450 mxr big bore kits
2008 polaris 450 mxr
2008 polaris outlaw 450 bigbore kit
big bore kit for outlaw 450 mxr
mxr450 vs450r
outlaw 450 big bore
outlaw 450 big bore kit
outlaw 450 mxr big bore kit
outlaw 450 vs 525
polaris 525 vs. 450
polaris outlaw 450 big bore kit
polaris outlaw 450 carb bore
polaris outlaw 450 mod
polaris outlaw 450 vs 525
polaris outlaw 525 big bore kit
polaris outlaw 525 piston and cylinder kit
polaris outlaw 525 s racing parts
polaris outlaw 525 vs 450 mxr
polaris outlaw 540 kit
2008 Outlaw 525s shifting problems wyo1bowhunter Polaris Outlaw 6 04-08-2011 02:37 PM
outlaw 525s johnyk39 Polaris Outlaw 2 02-14-2011 11:19 PM
2008 Polaris Outlaw 525s????? Miller10 ATV Performance Modifications 0 01-07-2011 08:00 PM
Outlaw 525s Exhaust 525s ATV Performance Modifications 3 11-01-2010 11:03 AM
2008 Outlaw 525s shifting problems wyo1bowhunter ATV General Discussion 0 04-07-2010 02:01 AM
