Old 02-14-2011, 11:03 AM
fastoutlaw69's Avatar
Member #12024
07 outlaw 500 engine trouble
Hey guys, new to the thread and had a couple questions. I have an 07 outlaw 500 that I drowned in the river a few months back. It started having some trouble shortly after. I am pretty sure that water was sucked into it through the air box. When you ride it, it makes good power through 1st and 2nd gear then it starts to "cut" out and miss through 3rd and 4th and will try and make up some of it's power back in 5th gear. I have done almost everything I know to to including:
changing oil and filter several times
drained all fluids and replaced
pulled carb/cleaned/didn't replace jets, werent clogged
changed air and fuel filter
changed plug
I think thats about it. I hope this makes some sense as it's hard to describe exactly what happens. Thanks and hopefully someone can help.
Old 02-14-2011, 04:22 PM
Old 09-26-2011, 06:58 PM
Brandoh's Avatar
Member #9026
Did you ever figure it out? I have one with a similar problem...
Lead, follow, or get out of the way. -Thomas Paine
07 outlaw
07 outlaw 500
07 outlaw 500 forum
how to change polaris outlaw 500 fuel filter
how to rebuild a polaris outlaw 500 engine
outlaw 500 engine
outlaw 500 fuel pump problem
polaris outlaw 500 carb 08
polaris outlaw 500 cuts out
polaris outlaw 500 motor
polaris outlaw 500 motor rebuild
polaris outlaw 500 motors
polaris outlaw 500 reverse cutout
polaris outlaw 500 vs 525
polaris outlaw fuel filter location
polaris outlaw fuel pump
polaris outlaw fuel pump removal
polaris outlaw replacement engine
Fan Trouble ???? bmount ATV Repair and Maintenance 5 02-14-2011 04:48 PM
outlaw 90 engine oil Blookie2 Polaris Outlaw 3 12-28-2010 05:39 PM
Outlaw 500 Part at bottom of engine. HELP brokenoutlaw Polaris Outlaw 5 12-24-2010 12:16 PM
1994 Polaris 350 engine trouble clerihew82 ATV Repair and Maintenance 3 11-18-2010 06:30 PM
outlaw 525 nothin but trouble rob1994 Polaris Outlaw 13 09-26-2010 11:04 AM
