02-26-2011, 11:16 AM
Member #12402
How to adjust gear shifter
How do i raise the shifter on an 08 outlaw so i can get my foot under it with mx boots on? Can only ride in my new balances and havent had time to look at it to see how it adjust up.
02-26-2011, 02:27 PM
Member #12402
need help asap
02-26-2011, 02:56 PM
Member #7044
With a guess, loosen bolt 15 and raise the shifter up.
May have to pull it out first from what look like splines.
This is a diagram for an `08 525.
Take care,
Scott Deeter
02-26-2011, 08:28 PM
02-27-2011, 07:08 AM
Member #12402
yup thats how you do it done it last night took maybe 5 minutes. Thanks do you know if any body parts (bumper, grab bar, etc) from the predator will fit the 08 outlaw 525s
02-27-2011, 10:22 AM
Member #7044
Your welcome, sorry can't answer your parts fitment question as I don't
know. Just took a stab at the shifter question with looking at the diagram
Take care,
Scott Deeter
02-27-2011, 10:51 AM
Member #12402
i figured thats how it was like any other atv just wanted to double check. thanks for the help
2008 Outlaw 525s
-renthal fat fars
-pure polaris nerf bars
-baffle removed
-shaved fenders
-red neon lights
02-28-2011, 01:19 AM
Member #10991
Shifting is controlled by levers at the handlebars, connected by cables to the front and rear derailleurs... he derailleurs--devices through which the bike's chain passes--move from side to side to shift the chain from one sprocket to the next..
03-10-2011, 01:55 AM
Member #12808
Make sure to put blue loctite on the bolt that holds the shifter, you will loose it if you don't. Recheck often for being loose.
ajust gear shifter on atv, how do you adjust the position of the shift lever on an atv?, how to adjust a shifter on a predator 500, how to adjust shifter on atv, how to adjust the shift lever on your quad, how to put the shifter on a atv, how to raise a shifter on a fourwheeler, how to tighten chain on polaris trail boss, outlaw 525s shifter, polaris 400l shifter adjustment, polaris 425 gear shift, polaris 500 atv gear mesh adjustment, polaris gear shift adjustment, polaris predator shift lever, polaris shift adjustment, polaris shifter adjustment, polaris sportsman shifter loose, polaris sportsman with sloppy shifter, shift lever predator 500, tighten a gear shifter on a atv
