Old 02-27-2011, 03:27 PM
OUTLAWMUDDER's Avatar
Member #12375
Thermostat Elimination.
Im thinking about eliminating the thermostat on my 525s. Ct racing recomends this and is suppose to let the outlaw run cooler. Just seeing if anyone else had done this mod, and the results of it.
2008 Outlaw 525s
FMF 4.1 Slip On
Wiseco 12.5:1
Rath racing intake
Old 02-27-2011, 04:00 PM
Ghost Rider's Avatar
Member #8854
It usually not a good idea to remove the thermostat, because your engine wont reach normal operating temperature, and that can cause a loss in power and poor gas mileage. At least thats what ive always been told.
2011 Sportsman XP 550 EPS
Front And Rear Rack Extensions, Rear Lock And Ride Box With Back Rest, Heated Hand Grips, winch, Fender Extensions, Front And Rear Bumpers, HID Lights, A-Arm Guards, Low Lock And Ride Windshield, Maxxis BigHorn 2.0 Tires.
Old 02-27-2011, 04:04 PM
cwlongshot's Avatar
I don't see why a ATV engine would be any different than a automobile...
IMHO its NOT a good idea. The thermostat is there for a reason, it allows the engine to get to proper temp for best operation. With more and more computer controls on our engines this is more and more important. Lo temps can cause sludge to form in the crank case. Fuel economy will likely also suffer... Again, as long as they are the same as cars and trucks...
Old 03-03-2011, 09:36 PM
CB BLR's Avatar
Member #12304
The thermostat elimination kit works very well when riding slow in the woods...or in hotter climates...
I have ridden mine without a thermostat from 28 degrees...to 103 degrees...before the thermostat removal...the fan would come on all the time when doing slower riding.
I do notice that the motor takes longer to heat up when I am riding in really cool weather...but I just leave the choke on longer...and let it warm up longer...a practice that prolongs engine life.
Per the other answers...this quad has a carburator...no electronic fuel injection.
Allen at CT ...as well as other reputable engine builders...know what they are talking about .
My KTM 525 dual sport motorcycle doesn't have a thermostat...it comes without one stock ...and it has almost 45000 miles on it without there being any problems.
Chris
P.S. sludge comes from using lousy oil...and not changing it often enough...especially if you are using old dinosaurs for lubrication instead of synthetics.
Old 03-04-2011, 11:10 AM
Member #12375
Thanks for the info. And i ride mostly woods, thats why i am considering it.
2008 Outlaw 525s
FMF 4.1 Slip On
Wiseco 12.5:1
Rath racing intake
Old 03-04-2011, 11:21 AM
CB BLR's Avatar
Member #12304
Glad I could help.
Chris
Old 03-10-2011, 01:37 AM
ffracing's Avatar
Member #12808
I don't agree with removing the thermostat. You have to think about how a cooling system operates to understand why. Thermostats main purpose is to keep engine temps constant. It warms engine quickly and helps keep system pressures constant. What most people do not think about is the other side of the spectrum. While one of its purposes is to warm engine quickly, the other is to keep coolant in the radiator longer letting the fan do its job before allowing it to recirculate back to motor which in effect leads to better cooling system efficiency. Fans are made to run at slow speeds in the woods, that's what they are for and work in unison together. Engines are designed to run at these temps. If your hot light is staying on and fan runs constant then I would have a look at radiator for being plugged. Deletion of any parts won't cure that.
Old 08-01-2011, 06:52 PM
SSJEFF's Avatar
Member #17317
The Cooling system on the outlaws is not like the system on an automobile.
Check out this link for more info. Outlaw Overheating Issues With Thermostat Mods
Old 08-04-2011, 06:05 PM
speedfreek's Avatar
Member #12099
Good discussion, thanks
Old 08-19-2011, 09:48 PM
outlawman 525s's Avatar
Member #5124
i went with ct's recomendation and here in the heat capital Las vegas,nv. it's does what they claim,thanxs ct.
in the world of outlaws,we band 2gather and run as the fastest of the fast.Laughing at the yamahoppers,and the rest of them slow rides outherepilot license required,i meant firearms,two gun minimum!!!!!!!!!!!!!!!!!!!!and maybe a few grenadiersnot here
2008 polaris outlaw overheating
do you need a thermostat in an atv
dose a outlaw 525 have a thermostat
ktm 525 thermostat
ktm 525 thermostat location
ktm thermostat eliminator
outlaw 525 cooling
outlaw 525 cooling mod
outlaw 525 oil cooler
outlaw 525 thermostat
outlaw overheating
polaris outlaw 525 cooling mods
polaris outlaw 525 fan
polaris outlaw 525 oil cooler
polaris outlaw cooling mods
polaris outlaw thermostat
polaris outlaw thermostat elimination
polaris thermostat
thermostat elimination ki for 08 outlaw
why does an atv have a thermostat
01 Sportsman thermostat issue Jeff Wright ATV Repair and Maintenance 1 08-23-2009 12:15 AM
