Old 03-16-2011, 05:30 AM
ferg_29's Avatar
Member #5213
Polaris Outlaw 2006 Starting Issue
Alright,
I have 2006 Polaris Outlaw 500, and recently it won't roll over at all. Earlier I boosted it and it rolled over fine ran it, worked good then shut it off. When I tried to restart had to boost again but this time there is nothing just clicking from the solenoid. I shorted out solenoid and just get a hum from the starter. Ok, so I thought it was the started removed starter and took it to a starter garage and they said the starter is absolutely fine. I bump started the bike, and it was actually running (as i was afraid that the bike was seized?). So from here i removed the magneto cover because I was told it could be something to do with the starter clutch or something?? Im lost at this point and it has been a continuous operation. If anyone else has any ideas, or has had a similar problem please let me know. I wanna get muddy soon
Thanks to this great site
Old 03-16-2011, 07:30 AM
OUTLAWMUDDER's Avatar
Member #12375
Does your battery have a good charge?
2008 Outlaw 525s
FMF 4.1 Slip On
Wiseco 12.5:1
Rath racing intake
Old 03-16-2011, 07:38 AM
ferg_29's Avatar
Member #5213
taking the battery right out of the equation right if boosting from another vehicle
Old 03-16-2011, 08:01 AM
Member #12375
I would still pull the battery get a full charge on it and give it a try, because you might not of had a good connection while boosting it your second time. Just a suggestion, I have had similar problems to yours and have done the same things. Good luck with everything.
2008 Outlaw 525s
FMF 4.1 Slip On
Wiseco 12.5:1
Rath racing intake
Old 03-17-2011, 04:43 AM
ferg_29's Avatar
Member #5213
when I bum started it, it wasnt running the greatest. It was running like it was firing at the wrong time and backfiring. I have tested everything to the CDI box. Will this prevent the bike from rolling over??? Cause it makes sense that the CDI box controls when to ignite spark
Old 03-22-2011, 12:14 PM
bainses's Avatar
Member #13191
Same Problem
Hey Man I have the exact same problem and cannot figure it out. Before it quite turning over with the starter I had problems getting it started which I was told the valves needed adjustment. Well I let it sit too long before I adjusted them and now I have the same problem as you. Let me know what you find out. Thanks
Old 03-23-2011, 09:12 AM
ferg_29's Avatar
Member #5213
Found out the problem, took starter off, cdi box off, everything electrical off. Sanded all conections and put back together. ATV is rolling over now, just have to put the carb and everything else back together geeze!!! Fianlly after 6 months
Old 03-23-2011, 01:29 PM
bainses's Avatar
Member #13191
Well I will try that hopefully mine will be fixed by doing the same thing as well. Thanks for the help.
Old 03-24-2011, 04:38 AM
ferg_29's Avatar
Member #5213
bike works amazing, other then it stalls sometimes after I let off the throttle, or go down hills or big bumps...hmmmm going to post a new thread and see what other riders think.
get a multimeter bainses and just start from the battery and keep working your way back. I couldn't find a 06 service manual so i downloaded the 09 (same components just different colour wires). Its got a flow chart in the troubleshooting to test for starting issues!!. This is what I did and it seemed to narrow down to where there was huge voltage lost!. Let me know how it goes and I can help you along the way. Hope you get the o'l girl going once again
Old 03-24-2011, 10:42 AM
bainses's Avatar
Member #13191
Thanks for the help won't be home for a couple weeks but I will let you know if it works and gets mine running. Sounds like you now have a valve or carb problem. I bet it's the carb if you haven't cleaned it and it has set for several months. Thanks again.
06 outlaw 500 problems
06 polaris outlaw trouble starting
2006 polaris 500 outlaw problems
2006 polaris outlaw 500 problems
2006 polaris outlaw electrical problems
2006 polaris outlaw problems
how much is a starter for a 2006 polairs outlaw 500
outlaw 50 wont start
outlaw 525 starter clutch
outlaw wont charge
polaris 50 won't start
polaris outlaw 50 owners manual
polaris outlaw 50 problems
polaris outlaw 50 wont start
polaris outlaw shorted out
polaris outlaw starting troubles
polaris outlaw will roll start
taking a battery out of a polaris outlaw 50
troubleshoot outlaw not starting
troubleshoot polaris outlaw 50cc
2006 Polaris Outlaw Won't Start ferg_29 Polaris Outlaw 12 02-21-2012 04:18 PM
2011 Outlaw starting issue jmk Polaris Outlaw 9 02-22-2011 02:19 AM
2006 Polaris Outlaw won't stay running! Outlaw Matt Polaris Outlaw 1 11-23-2010 05:25 PM
Polaris Outlaw 2006 ferg_29 Polaris Outlaw 2 06-01-2010 03:12 PM
2006 Polaris Outlaw 500 IRS gettherefast ATVs For Sale 0 04-15-2010 08:27 PM
