03-20-2011, 04:54 AM
Member #13106
A/F screw
Is there an A/F screw on an 06' Outlaw 525 IRS. I did not see it unless it has a cap on it.
03-20-2011, 05:59 AM
03-20-2011, 10:05 AM
Member #12304
It is up under the front of the carb...on the front bottom of the float bowl...yes it does have a cap on it.
Chris
03-20-2011, 01:18 PM
Member #13106
One more question for you but it may seem like a no brainer. The actual distance on turns. If I was to turn the a/f screw 3 turns out are they saying to bring it out 3 complete turns. 360 degrees for one turn or are they counting three ticks of the screw slot which would be 1.5 fuel 360 degree turns. I ask this because the local dealer service told my friend that it was counted by halfs. basically everytime the screw slot came to point it was 1 so a 360 degree turn would be two counts. Hope I didn't confuse anybody.
03-20-2011, 07:04 PM
Member #12304
A turn is 360 deg....three turns out would be 3x360 degrees. 1.5 turns would be 360 deg + 180 deg...or...a turn and a half
all of this from lightly bottomed...the number of turns is how far out you are turning the screw out... from lightly bottomed
Hope this helps,
Chris
2008 polaris outlaw 525 fuel screw, 2011 polaris 500 air fuel setting, how many turns out on the air mixture screw on a polaris 500, how to adjust the air and fuel on a polaris 500, is there a fuel mixture screw on a outlaw 450, outlaw 500 mixture screw, outlaw 525 fuel mixture screw, outlaw 525 fuel screw settings, outlaw525 factory feul mix setting, polaris 335 air/fuel adjustment, polaris 450 air screw, polaris gas cap outlaw 525, polaris outlaw 450 air screw, polaris outlaw 525 air fuel adjustment, polaris outlaw 525 fuel air screw, polaris outlaw air fuel screw, polaris ranger screws, polaris sportsman 500 air fuel mixture, where is the fuel mixture screw on a outlaw 450, where's my polaris outlaw air fuel mixture screw at
