03-30-2011, 04:12 PM
Member #8324
2006 outlaw wont start when cold but will start when warm.
Got my friend to buy an 06 outlaw for a good price after he sold me his 06 predator. He also bought a can am renegade to yank all of us out of the mud when we get stuck also. The problem he is having is that he cant start the atv off of the battery when cold but we can jump start it cold. After it has warmed up a bit it starts up off of the battery fine after riding it for a bit. His brther was saying that the valves have to be re adjusted. Is this correct. He doesnt quit know atv motors perfect but is a bike mechanic for Harley Davidson.Thanks Ken
03-30-2011, 05:56 PM
Member #13503
I was gonna say the valves or cam timing.
1999 Scrambler 500-HPD Exhaust system, Jetted, K&N Intake
2006 Sportsman 800- plow
2007 Outlaw 525IRS- Power bomb headers, FmF Muffler, Jetted, K&N Intake System, Viper speedo/tach, BOSS Nitrous Kit.
03-31-2011, 09:27 PM
Member #13553
If it is a ktm 450 or 525. I would be willing to say that i am 90% sure it needs the valves adjusted. I have had several RFS KTM bikes hard or slow start ups was the first sign of needing the valves adjusted esp. cold. search for KTM RFS valve adjustment video on you tube. takes about 10 min on a bike. Hope this helps.
04-01-2011, 05:27 PM
Member #8324
Thanks for your input guys. Im going to look that up on you tube
04-01-2011, 06:20 PM
Member #12861
Yeah I agree. My brother’s scrambler always started up fine then all at once it did not want to start. Once we adjusted the valves it had fired up great ever since. My outlaw always starts fairly well. It starts a little hard when it is cold and it has been sitting for a while. If you battery is fine I would check out the valve clearance and start there. Let me know how much work it is if you adjust your valves incase I ever have to do it. I wish outlaws have hydraulic valves like the newer sportsmans do. Also if the values are too tight you might not hear noise when it is running but if they are loose you should hear a little more engine noise but if you just bought it, it will be hard to tell if it is louder than normal.
2006 Polaris Outlaw 500
ITP Holeshot HD Tires
Polaris Outlaw Shock Covers
ProArmor Nerf Bars
ProBend Hand Guards with 55w Lights
Heated HandGrips
Trail Tech Endurance Speedometer
Current Quads
2010 Polaris Sportsman 850 EPS
2008 Polaris Sportsman 800 Touring
2006 Polaris Scrambler 500 H.O
My Past Quads
2005 Suzuki King Quad 700
2001 Yamaha Blaster 200
04-05-2011, 03:38 PM
Member #13553
The KTM RFS motors need a Valve adjustment about every 20 hrs. That sounds like it sucks but it was easier to do than the new models. The new models use shims. They dont have to have them adjusted as often but you have to all the possible shim combos in hand to do the job. The new models take about a half hour to do too. The older RFS motor didnt require anything except for a couple of .50C gaskets. and only takes about ten min. The upside to the new motor is they have needed zero adjustment for the last 125hrs. I check them to see and they havent moved since the first adjustment at 25hrs.
05-09-2011, 01:42 PM
Member #14577
07
holy crap mines does the same thing
ecept when i shut it off smell like gass .. no leaks ..
2006 outlaw 500 shims, 2006 polaris outlaw 500 wont start, 2006 polaris outlaw 500, hard to start, 2007 polaris outlaw hard to start, 2007 polaris outlaw valve adjustment, how many valves does a 2006 polaris outlaw 500 have, how to adjust valves on 500 outlaw, my outlaw 525 wont start when its cold, outlaw 500 valve adjustment, polaris 90 hard cold start, polaris outlaw 2008 90 cold starting, polaris outlaw 50 hard to start cold, polaris outlaw 500 valve adjustment, polaris outlaw 500 wont start, polaris outlaw hard to start, polaris outlaw wont start, polaris scrambler 400 will not start when cold,, predator 500 wont start in cold, predator 90 hard to start when cold, valve shim kit 2006 polaris outlaw 500
