Old 04-13-2011, 01:04 PM
davidjacob's Avatar
Member #12552
outlaw 2009 sprocket
Hi, I was wondering if this forum has a store or sponsor that sells 2009 outlaw rear sprockets??? My Polaris dealer sells the sprocket 85.00$... Which I think is not very reasonable. I changed my front sprocket to a 13 tooth if I remember well to give it more torque. I want to have the OEM sprocket which (correct me if I'm wrong) is a 38 tooth sprocket. I wanted to have a little more torque instead of top speed. As I can see on other online sites, the 38 tooth sprocket is discontinued.... Any help to find a OEM (preferably) sprocket would be appreciated.
Thanks in advance,
David
Old 05-02-2011, 02:36 AM
cmitchell79's Avatar
Member #14653
Which Outlaw do you have, IRS or SA? ATV Parts, ATV Tires, Dirt Bike Parts, Motocross Gear, Motorcycle parts and Motorcycle Tires | Rocky Mountain ATV/MC sells OEM parts for Polaris now. Also REBEL GEARS CUSTOM MADE MOTORCYCLE SPROCKETS ANY SIZE will make any sprocket you want but they are made out of aluminum.
06 Oultaw 500
-L8ton racing rear swaybar
-Rekluse
02 Sportsman 700
05 Predator 90
Special thanks to L8ton Racing
www.l8tonracing.com
Old 05-03-2011, 05:41 PM
davidjacob's Avatar
Member #12552
i have a irs
Old 05-03-2011, 05:48 PM
M_Quick's Avatar
Member #13816
What are you looking for a larger or smaller rear sprocket? And why are you wanting to change it? I understand the front sprocket change, if you went down a tooth for more low end. I did the same on my Trx700, but haven't thought about changing the rear.
2001 Polaris Scrambler 500 4x4
(2) 2003 Polaris Sportsman 90cc
2006 Polaris Predator 50
2008 Honda Trx700xx
Old 05-04-2011, 02:49 AM
Member #14653
Instead of dropping one tooth in the front I went to a 40 tooth rear sprocket.
06 Oultaw 500
-Rekluse
02 Sportsman 700
05 Predator 90
www.l8tonracing.com
Old 05-04-2011, 02:53 AM
Member #14653
One of the site sponsors Honda Kawasaki Polaris Suzuki Yamaha Motorcycles ATVS Scooters Utility Vehicles sells the stock OEM replacement.
SPROCKET-38T,RR,OUTLAW IRS 3222138 $47.12
They also sell the 40 tooth rear
SPROCKET-40T,RR,OUTLAW IRS ([Accessory] )3222183 $37.71
06 Oultaw 500
-Rekluse
02 Sportsman 700
05 Predator 90
www.l8tonracing.com
Old 05-05-2011, 11:51 AM
M_Quick's Avatar
Member #13816
Wow not sure on the Outlaw, but usally alot easier to change front sproket, and lots cheaper.
2008 Honda Trx700xx
Old 05-05-2011, 12:03 PM
Member #14653
Definitely easier to change the front sprocket!, I needed new front and rear sprockets anyway so I went bigger on the rear.
06 Oultaw 500
-Rekluse
02 Sportsman 700
05 Predator 90
www.l8tonracing.com
Old 05-06-2011, 05:54 PM
davidjacob's Avatar
Member #12552
Originally Posted by M_Quick View Post
What are looking for a larger or smaller rear sprocket? And why are you wanting to change it? I understand the front sprocket change, if you went down a tooth for more low end. I did the same on my Trx700, but haven't thought about changing the rear.
I finally changed le front one with ease but I still need to change the rear one cause it's due to be changed anyways. The teeth are starting to tilt downwards and I am planning to but an oem one...
Old 05-06-2011, 05:57 PM
davidjacob's Avatar
Member #12552
thanks for the help!
2006 polaris outlaw 500 sprocket replacement
2009 polaris outlaw 450 modifications
2009 polaris outlaw 450mxr sprocket size
2009 polaris outlaw 525 irs stock sprocket sizes
40t sprocket polaris preator 90
500 outlaw 2006 rear sprocket irs
best front sprocket on 525s
can i change front sprocket on 2009 polaris scramble
how many teeth on sproket on polaris outlaw 90
how to remove polaris 90 rear sprocket
howmto change a honda 700 atv front sprocket
outlaw 500 13 tooth sprocket
outlaw 500 front sprocket removal
outlaw 500 stock sprocket sizes
outlaw 90 bigger sprocket
polaris outlaw 50 front sproket
polaris outlaw 500 sprocket change
polaris predator 90 rear spocket 40 tooth
sprocket for 06 polaris outlaw 500 irs
what can i do to my 90cc atv to have more low end power
Outlaw 525 Sprocket nitrex ATV Performance Modifications 13 01-15-2011 09:06 AM
2009 outlaw 90 start pickleray ATV Repair and Maintenance 4 12-27-2010 10:53 AM
2009 Outlaw 525 irs Lord Rahl ATV Performance Modifications 1 03-18-2010 08:10 PM
2009 Polaris Outlaw 525 S Prddave 2009 0 03-08-2010 01:38 PM
2009 Polaris Outlaw 450 MXR Prddave 2009 0 03-08-2010 01:08 PM
