Old 05-04-2011, 07:11 AM
erichter66's Avatar
Member #14681
What is the best way to LIMIT power? (for kid use)
I realize this is the exact opposite of what everyone else is trying to do here, but I am buying 2008 Outlaw 525 S for my 16 yr old daughter. I would like to possibly limit the power output by way of some spacer that does not allow the throttle to be pushed all the way, until she gets more comfortable on it.
I know that the wisdom of this decision is questionable, but she rides 550lbs Yamaha Big Bear 400 pretty well. Raptor 250 did not have enough power for her. I did want something lighter for her but when I looked at Raptor 350, Kawasaki KFX400/Suzuki LTZ400 and the Outlaw 525, they all weigh 375 lbs. dry weight +_ couple of lbs. This will save me from buying another quad later. The main goal here is to allow her to ride with us in Ouray, Colorado in September. Small quads don't do well up in that altitude.
Old 05-04-2011, 11:54 AM
4getful2's Avatar
Member #1234
Polaris used to make a throttle stop. Check with the dealer ,it mounts next to the thumb throttle and will only allow you to go at the set rpm
Old 05-04-2011, 04:59 PM
Chevy55's Avatar
Member #14569
If she handles the power of others no problem, why not have her learn and respect the full throttle power. Only real reason I state this is we got my son (7) a polaris outlaw 90, and turned it down to about half throttle...low and behold we're at the cabin and he goes to climb the little hill in back (which is a decent angle) and because he doesn't have enough juice he can't can't the machine up over the crest...well fortunately before he tips backwards as he applied the breaks and is sitting back on the seat, dad (me) was there to grab the front end..where as we both learned a lesson...don't brake on top of a steep incline or at least if you do throw your weight up over the handlebars, and dad (me) ensure he has enough throttle to keep him out of harms way...
Just a story I thought I would share,
Cheers
Chevy55
Old 05-04-2011, 06:07 PM
LEOGM5150's Avatar
Member #14419
i agree. unless it is on flat ground limiting power could be as dangerous as too much power. i would say let her ride under supervision, tell her to stay off the throttle and stay in 2nd gear until she is ready or you are confident.
if you must do it. most aftermarket thumb throttles or honda or yamaha thumb throttles have a set screw. here is the aftermarket one i have on my outlaw 525
i even think some of the stock polaris ones have a 10mm set screw on the under side of the thumb throttle. may just be the older ones though.
2007 OUTLAW 525 IRS
2005 TLD PREDATOR HOT SEAT 600
2003 PREDATOR 500
2001 400 TWO STROKE SCRAMBLER
PLUS A DOZEN OTHERS...
04 kfx 400 throttle screw
2007 polaris predator 90 throttle control
atv throttle limiter
atv throttle stop
does the kfx 400 have a throttle screw
how to adjust polaris predator 50 throttle
limit throttle on polaris atv
need throttle screw for polaris outlaw 50
polaris 525 aftermarket seat
polaris outlaw 525 vs suzuki ltz 400
polaris scrambler 50 throttle set screw
polaris throttle for kids
size of the throttle stop screw on a 06 polaris 50
throttle restrictor screw for honda atv
throttle set screw for 2004 polaris predator
throttle set screw for 2005 polaris predator
throttle stop atv
throttle stop screw polaris 50
throttle stop screw polaris 90
used thumb throttle for atv
06 sportsman no power intell power is disconected and reconected jwiggin3021 ATV Repair and Maintenance 6 05-19-2012 12:19 AM
Limit Switch for Plow Lowesthertz ATV General Discussion 2 01-01-2010 02:20 PM
2004 Scrambler lost rev limit and awd Scrambled Eggs Polaris Scrambler 1 12-26-2009 05:00 AM
525? Whats the max oversize limit on a 500 cylinder? atvjunkie821 ATV Performance Modifications 0 12-21-2009 05:35 PM
No power to the Pod grizzly02 ATV Repair and Maintenance 2 09-21-2009 01:33 PM
