Old 05-05-2011, 05:46 AM
2010outlaw's Avatar
Member #14393
Question Suspenion and plastics
Wanting to Widen the 2010 Polaris 525s, What are some good companies.
Whats your thoughts on just using wheel spacers ?
Ive just recenlty rolled my Outlaw, so its time for some new plastics. Does anybody know of any good companies to get plastics from ?
I need all front plastics atleast, Id like to get black ones if possible.
If you have any pics of Post em.
Old 05-05-2011, 05:54 AM
LEOGM5150's Avatar
Member #14419
check ebay for plasitcs. maier plastics are great but very spendy. i have run wheels spacers and still do they are good, but not as good as extended arms and hubs. rath racing makes very nice billet +3 hubs. i have run them for years they are bullet proof. here is a link
Rath Racing Online Store: KTM450/525/505
2007 OUTLAW 525 IRS
2005 TLD PREDATOR HOT SEAT 600
2003 PREDATOR 500
2001 400 TWO STROKE SCRAMBLER
PLUS A DOZEN OTHERS...
Old 05-05-2011, 06:37 AM
2010outlaw's Avatar
Member #14393
I have checked with Maier, prices are great but expensive shipping to Canada 200+. So you run the MX version of the hubs which make it a 6+ kit or 1.5" per side ? What should i do for the front ??
Old 05-05-2011, 08:56 AM
crimson850's Avatar
Member #5005
RATH anything is awesome. Why are you wanting to widen it? flat track or TT racing?
2010 Polaris 850XP LE crimson red edition.-TOTALED
Pure polaris front and rear deluxe brush guards.
Pure polaris front and rear a arm guards.
Pure polaris lock & ride tall windshield
Pure polaris lock & ride gun scabbard
Pure polaris steel rear rack extender
ITP terra cross tires
Maxxis RAZR 4 speeds
UNI air filter
oury grips
RATH racing pre runner style chromoly bumper (front)
Ricochet Skid Plate (chassis)
Hot seat performance hypershift clutch kit
SSI decal kit
Powermadd handguard factory rider.
For any of your performance needs I would go with only Hotseat performance. I dont work for them just love there GREAT service and their amazing products[/SIZE][/SIZE][/SIZE]!
Old 05-05-2011, 09:32 AM
2010outlaw's Avatar
Member #14393
Want to make it wider just for the handling and stability, a lot of fast trails through the woods were i live. Its seems like Rath is the company that makes a majority of the parts for the 525s. Is there any other company to look at ?
Old 05-05-2011, 01:25 PM
LEOGM5150's Avatar
Member #14419
it is 1.5 inches per side. then i run spacers in the front.
here are the one i run on e one of them.
Polaris 850 550 ATV Wheel Spacers 4/156 1 1/2 Wide | eBay
here are the one i run on another
Two 2.0" Wheel Spacers 4/156 to 4/156 10mm Lug | eBay
the other one i run rath +3 a arms
here is how they look widened out in a row.
the 2 polaris predators are 50 inches wide in the front and rear. the outlaw is 51 inches wide in the front and 53 inches wide in the rear.
2007 OUTLAW 525 IRS
2003 PREDATOR 500
Old 05-06-2011, 04:27 AM
2010outlaw's Avatar
Member #14393
Very Nice, What all do you have done to the Outlaw
Old 05-06-2011, 06:05 AM
LEOGM5150's Avatar
Member #14419
it is a 2007. it has 2008 plastics, with a maier hood. 2009 heel guards 2009 seat with pin latch and a quad tech seat cover. with ims roll pegs with kickups. i have fox float front shocks. with 2006 outlaw 500 irs rear fox podium resi shocks with quad rate springs valved for a 250 pound guy(too bad i am 275lbs). a hot cam. 41.6mm bored carb. a fmf megabomb pipe and hmf sport silencer. a pro flo intake with k&n filter and prefilter outerware. a lc1 innovate wideband o2 sensor and gauge. asv levers and mounts, honda front brake master cylinder. predator spindals, with hard core hubs and tapered bearings. hpd steering stabilizer. flex bars. rath anti vibe steering stem. polaris bob oil cooler adapter with a lockhart oil cooler. inline coolers. odi grips. teixeira upper and lower balljoints, and thermostat eliminator kit. custom built lowering lower a arms. douglas ultimate beadlock rims. 51 inches wide in front and 53 inches wide in rear. lowered front and rear 2.5 inches. pure polaris front bumper. pro armor rear grab bar. stiffer stainless rear swaybar. maxxis razr 2 front tires maxxis razr pr 10 inch rear tires.
so my question is what haven't i done. answer big bore, oversized valves a wilder cam and porting. i am buying a second engine right now and i am going to send it off to dave hopkins and have him build a fire breathing 570 to get just a bit more power i am looking for 65hp.
2007 OUTLAW 525 IRS
2003 PREDATOR 500
Old 05-06-2011, 07:04 AM
2010outlaw's Avatar
Member #14393
Crazy, Deffienetly far from stock.
thermostat eliminator kit ? what is the benifit to that
why did you get custom built lowering lower a arms ?
Do u like the A-arms you can buy from rath ( MX version )
Just trying to learn about what i should do for mine
Old 08-20-2011, 07:11 PM
LEOGM5150's Avatar
Member #14419
the thermostat eliminator kit lets it run cooler and blocks off the lower cylinder bypass hose. hot coolant will flow back into your cylinder when the thermostat is closed or when the flow is more than the thermostat can take.
i got mine from teixeira tech
Product Detail
here is my review of it on my site.
Polaris Pro Riders
the lowering arms lower the front for free. that is why i use them. i will try rath arms when i have an extra $500 at the same time as i find a used set for that amount or less. i am not a racer so a grand for a arms is not in the budget.
2007 OUTLAW 525 IRS
2003 PREDATOR 500
05 polaris 50cc predator plastic
2003predator 500 atv
2005 polaris predator 50 plastics
2007 polaris outlaw 525 front plastic
500 scrambler irs conversion
525irs douglas
outlaw 50 plastic
outlaw 50 wheel spacers
outlaw racing plastics
polaris outlaw 50 plastic
polaris outlaw 525 irs plastics
polaris outlaw 525 plastics
polaris outlaw 525 rear plastic
polaris predator 50 wheel spacers
polaris predator spacers 2.5
polaris predator wheel spacer
polaris predator wide kit
polaris sport 400 plastics
quad polaris outlaw irs
wheel spacers polaris predator
850 Plastics ktmwoodsman ATV General Discussion 8 09-30-2011 05:11 PM
Plastics Bigriver ATV General Discussion 4 03-08-2011 07:20 PM
Plastics coad7 ATV Racing Discussion 1 02-23-2011 07:51 PM
Need help....plastics!! coad7 ATV General Discussion 2 10-11-2010 07:30 PM
!!!plastics!!! outlaw87 ATV Parts for Sale 4 08-25-2010 04:30 PM
