Old 05-08-2011, 08:36 AM
CORNfedREBEL's Avatar
Member #12430
Replaced rear inner boots have a major question
when i removed the shafts i noticed that the bearing cages were opposite on both sides, well actually they were pointing in the same direction which is wrong, one had the bigger part of the cage facing in toward rear hub and the other side was facing outward toward the tire. so which is the correct way. i also noticed the inner bearing race that is pressed on the shaft is beveled on the end wich way is that supposed to go on the shaft. i need to know asap supposed to go riding today!
Old 05-09-2011, 04:43 PM
Member #12430
come on i know im not the only one who has replaced these boots, i called the dealership they had no idea want me to make an appointment, charge me mony, to look at it wtf... these bearing have to be removed in order to replace boot so i know someone has to know which way they go, is there a way to contat polaris directly to find out?
08 outlaw inner boot fit
boot for rear polaris
changing the rear cv boots on the 525 outlaw polaris
cv boot for polaris outlaw
how do the bearing in rear inner shaft polaris outlaw
how the bearing cage goes in a polaris 525
how to change inner cv boot polaris outlaw
inner boots
inner cv boot install polaris
inner cv boot replacement outlaw
inner rear cv
installing cv polaris outlaw
outlaw inner rear boot
polaris cv bearing cage
polaris cv bearing cage symmetric
polaris oulaw inner cv bearing
polaris outlaw inner cv boot
polaris outlaw rear hub
polaris xp 850 axles
removing inner boot for 525 outlaw
Just replaced flywheel and now it stalls...? herman0203 Polaris Predator 9 05-13-2011 12:47 AM
Replaced Radiator now runs hot? Eddy Polaris Sportsman 8 12-14-2010 07:31 AM
Rear CV boots keep breaking. crimson850 ATV General Discussion 0 08-25-2010 07:10 PM
92 Trailboss replaced starter won't start bruce ATV Repair and Maintenance 3 03-01-2010 02:27 PM
Major ecm recall donwest ATV Repair and Maintenance 2 01-14-2010 03:18 PM
