05-10-2011, 04:58 AM
Member #14909
Proud owner of a new 10' 525s
Hey guys im a proud owner of a new Outlaw 525S. anything i should know right off the bat? as far as mods go.... hmm where to start?
05-10-2011, 05:11 AM
05-11-2011, 01:35 AM
Member #12454
congrats and welcome to the board! im not the mod guy or id suggest something
05-11-2011, 04:34 AM
Member #14393
Well on my 525S 2010 i have put a Pure Polaris FMF Silencer Slip On and a DynaJet Jet kit and took of the Air Box cover and i find it works great now. I have not dynoed it yet, but its on my list of things to do
POLARIS
have so good ideas on here also
06-06-2011, 04:01 PM
Member #15669
Some good advice from 2010outlaw, I'd start with a pipe and jetting kit for the carb and take off the airbox or purchase the EHS performance lid. Should all be less than $500-600 bucks and will give you a lot more HPs right out the gate. Also, nerf bars are essential IMO
'07 Outlaw 525 IRS
HMF Elliptical Exhaust/MoorePower Ceramic Header
K&N Filter/EHS airbox lid/JD Jet Kit
MotoX coated A-Arms/Nerfs/Bumber/Grab Bar
Pingel Kill-Switch/Wrath Anti-Vibe Clamp/Pro-Taper bars
06-07-2011, 12:59 PM
Member #7775
First thing is get ride of the cheeze dick handlebars and add remote reserviors to the front shocks. Just look for my post in the outlaw section.
06-08-2011, 02:40 PM
Member #15669
Terrasmak, where did you get the remove reservoirs for the front shocks? About how much $$? Definitely sounds like something I'd be interested in.
'07 Outlaw 525 IRS
06-10-2011, 08:45 AM
Member #14909
Thanks guys for the response. yea im thinking of going with the ct exhaust with jets and all. Ive been looking at the airbox and it seems rather restrictive. if seen some pple put the cfm aluminum airboxs. anyone have and good results or luck from these? and yea the nerf bars are a must i bought the oem polaris stars when i bought the quad. and as far as remote reservoirs... my quad isnt a 450mxr so no reservoirs for me, only in the rear
06-20-2011, 12:33 PM
Member #7775
Newest mods, Tusk chub bars, and remote reserviors read this , and it also has the link to where i bought the reserviors my mine. Well worth the upgrade.
06-20-2011, 01:37 PM
Member #16144
Uncorking the KTM
Throw the airbox in the attic. Get a 6 inch angled uni clamp on two stage filter oiled up real good with filter oil. Dennis Kirk has them for like 19 bucks #305049. Then install a fmf right side slip on exhuast. Then go get yourself a 190 main jet for the carb and a moose adjustable fuel screw. Start off with the fuel screw turned out to stock and adjust the screw to make it run clean right when you crack the throttle open. Likely richer a 1/4 turn or so. You may want to get the carb bored out by a reputable machinst to say 41.5mm. clean the filter every ride. Keep the radiator clean cuz they like to run hot. You can also plug the coolant bypass with a hose, clamp, and a aluminum plug on the front of the cylinder. Then just run the hose from the radiator to the top of the head with no kinks in the hose.
Thats a good start to getting that motor to breath. It will shred real good with that set up.
adjust outlaw 525 shocks, adjusting shocks on polaris outlaw, air box 525 s, best 2010 polaris outlaw 525 s cmf air filter, cfm airbox outlaw, cfm outlaw 525s airbox, outlaw 525 coolant bypass, outlaw 525s shock upgrade, pilaris outlaw shock upgrade, polaris 450mxr oil, polaris 525s pipe and jet, polaris atv coolant outlaw 525s, polaris outlaw 525s front shocks, polaris outlaw clamp on filter, polaris outlaw coolant line bypass, pro taper polaris outlaw, stock 525 s jetts, uni air filter 2008 polaris outlaw 525 s
