Old 05-29-2011, 12:09 PM
CORNfedREBEL's Avatar
Member #12430
Switch wheels to opposite side
i just ot done putting two rear boots on and while i had the wheels off i came up with this not so brilliant idea, to swap the wheels side to side and flip the wheel inside to outside (maintains proper tire rotation), i did this on the front also, i havent got to ride it yet but it totally looks badass and the stance is really wide and looks like i have axle extensions on. just wondering if i am going to break something when i ride it since there will be more stress on studs and shafts, has anyone done this and what did you think
Old 05-29-2011, 02:56 PM
cwlongshot's Avatar
Please look closely at your valve stems they will hit the brakes on one side in back (On a sportsman) and a couple things up front. They will not last long.
You could of coarse remove valve stems.. Then weld the holes up and drill new ones.
Yes you will be exerting allot more stress on your hubs and axles as well.
Old 06-05-2011, 11:50 AM
speedfreek's Avatar
Member #12099
I did this on the front of my 08 Outlaw 525. I think it looks bad a$$ too. Got the deep dish look and widened the stance too! Now the front and rear are exactly the same width.
Old 06-05-2011, 12:18 PM
Popo 500's Avatar
Member #10396
Take some pics of how it looks like that. Id imagine that would look pretty cool. A wider stance is always nice
2010 Sportsman 500HO
Big Gun Full Exhaust / Jet Kit / K&N
28" Zillas on SS212 Black / 2" RDC Lift
Front & Rear Rack Extension / Front & Rear Bumpers
Hand Guards / 3000lb Winch
HID with 3 Light Mod / Reverse Override
Wifes:
2002 Sportsman 400
Rear Rack Extension
Hand Guards
2000lb Winch
Old 06-06-2011, 04:05 PM
OutlawJim's Avatar
Member #15669
Okay, I just talked with my Polaris guy who said DO NOT switch out the front wheels and if you have to widen your front, go with spacers. HOWEVER, you can switch out the rear wheels with no real harm, as the rear bushings take the punishment anyways. I just did it to mine and it does look pretty rad with the narrower front and about 3" wider per side on the rear
'07 Outlaw 525 IRS
HMF Elliptical Exhaust/MoorePower Ceramic Header
K&N Filter/EHS airbox lid/JD Jet Kit
MotoX coated A-Arms/Nerfs/Bumber/Grab Bar
Pingel Kill-Switch/Wrath Anti-Vibe Clamp/Pro-Taper bars
can i reverse tire rims
can rear 20 in rim be switch to the front
deep dish polaris wheels
deep dish reverse wheels
deep dish wheels for polaris outlaw
flipped atv rim wider stance
handguards for polaris outlaw 525 irs
how to put moose racing handguards on a polaris outlaw 525
how to widen 525 outlaw
irs 525 outlaw epi cv boot
outlaw 525 irs wheels
polaris deep dish rims
polaris outlaw 525 irs rims
polaris outlaw 525 irs wheels
polaris outlaw 525 irs with deep dish rims
polaris outlaw 525irs rims
polaris xplorer flipped front rims
rims to narrow outlaw 525
what is the opisite of deep dish wheels
which offset for outlaw 525
Trouble with 700cc Ranger side-by-side? Glen Kenney ATV General Discussion 6 09-11-2011 09:52 AM
Switch on side of light on 95 xplorer Belldenpugs ATV Repair and Maintenance 2 04-15-2011 11:25 AM
Opposite Lock Vic Winch+ RZR's 20-21 May 2011 Wildwood Vic MrsSmith ATV Racing Discussion 1 04-12-2011 05:50 AM
Grab front left wheel and moves side to side--help.. adicted ATV Brakes & Suspension 3 01-13-2011 06:35 PM
Wanted: 1999 Polaris 400 4x4 scrambler Left side control switch michaelbell85 ATV Parts for Sale 0 06-24-2010 07:06 AM
