Old 06-23-2011, 02:51 PM
old 99 sport's Avatar
Member #4280
ratleing sound
my sons 08 525s started making deep rattleing sound from left side of engine when you pull clutch in it stops or if you put in gear with clutch pulled it rattles.we took both side covers off just a little in and out play at crank no up and down play though.we had clutches out they looked ok also.has anyone else had this sound coming from bottom end.with clutch pulled in motor revs fine in neutral ?
Old 06-25-2011, 05:28 AM
OutlawJim's Avatar
Member #15669
The KTM 525 motor has a known "knocking" issue....there is a bolt on the bottom of the crank that can come loose. My Polaris mechanic and I took mine apart and put red lock-tite on it to ensure that it doesn't ever come off again. This could definitely be what you are hearing!
'07 Outlaw 525 IRS
HMF Elliptical Exhaust/MoorePower Ceramic Header
K&N Filter/EHS airbox lid/JD Jet Kit
MotoX coated A-Arms/Nerfs/Bumber/Grab Bar
Pingel Kill-Switch/Wrath Anti-Vibe Clamp/Pro-Taper bars
Old 06-25-2011, 06:39 AM
speedfreek's Avatar
Member #12099
The 525 clutch is known to be very noisy. I have read several things about this and everyone says it is ok. I hate the noise that my clutch makes. One day I am going to take it apart and see why it sounds like this. It sounds like it is going to explode!
Old 06-26-2011, 05:06 AM
Member #4280
thanks for the input guys.
crank play ktm 525
engine noise ktm 525sx
how to tighten crank nut on outlaw
ktm 525 bottom end knock
ktm 525 bottoming out?
ktm 525 crank nut
ktm 525 engine noise
ktm 525 engine sounds
ktm 525 knock
ktm 525 motor mechanics in ohio
outlaw 525 crank rattling
outlaw 525 engine noise
outlaw 525 engine noisy
outlaw 525 irs knocking sound when turning
outlaw 525 loud knock clutch in and nuetral
outlaw 525 motor issues
polaris clutch tapping noise
polaris outlaw 525 crankshaft lock bolt
polaris outlaw clutch
polaris outlaw engine noise
how does this sound rkpalm ATV Purchasing and Price 2 12-19-2010 04:50 AM
Sound systems cwlongshot ATV General Discussion 20 12-17-2010 03:07 PM
clicking sound bird barrel ATV Repair and Maintenance 2 10-08-2010 10:18 AM
This May Sound A Bit Strange.... dl_craftsman ATV Repair and Maintenance 3 09-22-2010 11:15 AM
sound InkedAdrenaline Polaris Outlaw 3 09-08-2010 03:47 PM
