Old 07-12-2011, 02:14 PM
croghan23's Avatar
Member #12402
Unhappy Outlaw doesn't want to start every time
my 08 outlaw 525s doesnt want to start every time and it seems to be flooding its self out because if you let it sit for awhile it will start right up. im not sure where to start looking to fix the problem any ideas?
2008 Outlaw 525s
-renthal fat fars
-pure polaris nerf bars
-baffle removed
-shaved fenders
-red neon lights
Old 07-12-2011, 03:52 PM
speedfreek's Avatar
Member #12099
Mine starts fine when cold but has to be choked or it wont start. When it is warm i cannot give it gas or it is harder to start. Had to figure this out with a little time.
Old 07-12-2011, 04:37 PM
croghan23's Avatar
Member #12402
Mine just started doing this the other day. i use to not even have to choke it. i was putting my neon lights in it the other night and saw gas dripping from the steering stem.
2008 Outlaw 525s
-renthal fat fars
-baffle removed
-shaved fenders
-red neon lights
Old 07-13-2011, 03:53 PM
OutlawJim's Avatar
Member #15669
The gas dripping from the steering stem may just be the tank vent overflow. Outlaws have self-venting tanks with a small hose that comes down the steering stem.
Did you purchase the atv new or used? It may have an aftermarket exhaust or jet kit that makes it a little more difficult to start. You can also check the carb
'07 Outlaw 525 IRS
HMF Elliptical Exhaust/MoorePower Ceramic Header
K&N Filter/EHS airbox lid/JD Jet Kit
MotoX coated A-Arms/Nerfs/Bumber/Grab Bar
Pingel Kill-Switch/Wrath Anti-Vibe Clamp/Pro-Taper bars
Old 07-14-2011, 10:16 PM
croghan23's Avatar
Member #12402
the outlaw is completely stock and bought it the day it came out...cleaned the air filter and seems to be doing fine now
2008 Outlaw 525s
-renthal fat fars
-baffle removed
-shaved fenders
-red neon lights
Old 07-26-2011, 08:46 AM
mikpeet's Avatar
Member #11716
Same story here too. When it's hot don't touch the gas or it will not start. Normally has not been an issue. Just took some getting use too.
Mike
Outlaw 525 IRS
Outlaw 90 Clutch, Jet and Intake kit by Hot Seat Performance
Sportsman 500
Scrambler 50
Old 07-30-2011, 11:33 AM
croghan23's Avatar
Member #12402
come to find out someone put the wrong grade gas in it lol
2008 Outlaw 525s
-renthal fat fars
-baffle removed
-shaved fenders
-red neon lights
Old 07-30-2011, 06:56 PM
mikpeet's Avatar
Member #11716
Gas does make a difference. Service manual states at least 92 octane. With a 11:1 compression ratio it's expected.
Mike
Outlaw 525 IRS
Sportsman 500
Scrambler 50
Old 08-31-2011, 07:48 PM
outlawrider33's Avatar
Member #18226
i run 91 octane with octane booster in my outlaw
Old 09-15-2011, 03:07 AM
outlawman 525s's Avatar
Member #5124
i run a blended mixed gas of 100 octane and 92 octane.
in the world of outlaws,we band 2gather and run as the fastest of the fast.Laughing at the yamahoppers,and the rest of them slow rides outherepilot license required,i meant firearms,two gun minimum!!!!!!!!!!!!!!!!!!!!and maybe a few grenadiersnot here
2011 polaris 90 doesn't run good
2011 polaris 90 hard start
2011 polaris 90 hard to start
90 polaris outlaw carb issues
does polaris 525 have a choke
how to take baffle out of outlaw 525
how to time a 525 outlaw
outlaw 525 starter problems
outlaws doesn't open
polaris 525 dont start
polaris 90 outlaw starting problems
polaris outlaw 2008 90 cold starting
polaris outlaw 525 not starting]
polaris outlaw 525 starting problem
polaris outlaw 525 will not start
polaris outlaw 525 wont start
polaris outlaw 90 carburetor problems
polaris outlaw 90 crank but will not start
problems starting 2011 polaris outlaw 90
trouble starting my polaris outlaw
2006 outlaw wont start when cold but will start when warm. heavyritefoot Polaris Outlaw 6 05-09-2011 01:42 PM
2009 outlaw 90 start pickleray ATV Repair and Maintenance 4 12-27-2010 10:53 AM
Outlaw 525 Hot start issue bubbaK Polaris Outlaw 9 08-26-2010 08:31 PM
01 400 sportsman hard time with cold start chris.wishart ATV Repair and Maintenance 2 08-18-2010 03:18 AM
Pull start doesn't work mnnightowl ATV Repair and Maintenance 2 01-07-2010 03:03 AM
