08-14-2011, 04:51 PM
Member #12632
2010 Outlaw 525 S Backfiring
Hey guys I just got a brand new 525 outlaw. Just broke it in yesterday and today. The only bad thing is that it loves to backfire every time I take my thumb off of the gas. Is there anything I can do or should I bring it to the dealer as it is only a week old.
thanks guys.
08-14-2011, 05:01 PM
It's not jetted right. It never is brand new. It's probably lean. Can you tell if it's a lean backfire or a rich backfire? It's going to need to be rejetted based on you elevation and temperature range.
No big deal, really.
When/if you can, I highly recommend you get a JD jetting kit when you rejet. It will come with everything, but the golden piece of that kit is JD jettings needle. You will get a noticeable throttle improvement by just the needle alone, properly jetted of course.
Dealer should be able to do all of this easily. Very routine.
08-14-2011, 07:25 PM
Member #12632
Thanks for the fast reply. Does the JD jetting kit show you how to rejet it properly?
I live on the Upper Michigan / Canada boarder.
08-16-2011, 01:15 PM
Member #7775
Yes, if you can read an owners manuel, you can figure out a JD jet kit
08-16-2011, 04:46 PM
Member #12632
Hey guys is there any adjustment that I can do with the stock setup until I get a kit in?
02-06-2012, 04:09 PM
Member #6300
No, you need the kit and it will fix everything. Mine did the same thing until I jetted.
2010 OutLaw 525
02-06-2012, 04:43 PM
Member #21911
I'd just take it back to the dealer and have them fix it under warranty. Why should you invest in a jet kit at this time when it's still under warranty?
02-06-2012, 04:45 PM
Member #6300
Because you will need a jet kit eventually anyways
2010 OutLaw 525
02-21-2012, 08:31 PM
Member #1240
I realize this is a old post, but thought I would offer my findings... I agree a new bike shouldn't need any additional jetting, parts, anything at all to run right. Most of the Outlaw's pop through the exhaust when you let out of the throttle from a exhaust leak at the exhaust flange to head pipe fit.
-I solved my popping through the exhaust by taking the exhaust flange off of the head and pressing a socket slightly large enough to make a tight fit when you slide the head pipe on. My first thought was to break out the big welder. But there is a bolt in-between the two ports. So welding the flange to the head pipe will cause access issues to that bolt. I race a good bit of sand drags so I have countless passes then letting off the throttle to idle. It has been the way to go. I have 2 other friends with outlaws, and they have done this fix as well. I have also taken it apart and went back together with no issues as well.
-Greg
02 Polaris Scrambler 500 4X4
06 Polaris Phoenix 200
08 Polaris Outlaw 525s Thumper Racing 570 stage 3 kit
11 Polaris RZR 900XP
06 Sea Doo GTX 215HP Limited
11 Sea Doo RXT 260HP
04 Chevy Silverado
09 Nissan Altima 2.5SE
09 Toyota Highlander 300HP Limited
02-22-2012, 10:33 PM
Member #5124
try the fcr screw avail on ebay-it allow's for finer adjustments.not the stock adjustment screw,you'll see it
 in the world of outlaws,we band 2gather and run as the fastest of the fast.Laughing at the yamahoppers,and the rest of them slow rides outhere  pilot license required,i meant firearms,two gun minimum!!!!!!!!!!!!!!!!!!!!and maybe a few grenadiers  not here
08 outlaw 525 backfire when letting off, 08 outlaw backfires, 2010 outlaw 525s, 2012 outlaw 525, outlaw 525s jetting, polaris 50 outlaw backfiring, polaris atv 525, polaris outlaw 50 backfiring, polaris outlaw 525 backfire, polaris outlaw 525 backfires, polaris outlaw 525 dying, polaris outlaw 525 exhaust leak, polaris outlaw 525 forum, polaris outlaw 525 jetting, polaris outlaw exhaust leak, polaris outlaw forum, polaris outlaw talk, why does my 525 outlaw backfire when off the gas, why does my atv backfire, why does my outlaw back fire
