Old 12-07-2009, 01:30 PM
killerlee's Avatar
Member #2209
Broken Shifter rod (525)
Went to shift and the shifter bolt snapped off. Unable to get broken stud out. I need to know if I take the side of the case off can I push the shift shaft through without the bearings, seals and what ever else falling out. Thanks
Old 12-07-2009, 03:52 PM
im only a parts guy, not a tech so i dont know the answer to your question, but i am providing you with a parts diagram. i hope it helps somewhat so you know what to expect when you get in there. sorry i cant help more
# Add Part# Description Quantity
1 1332565 Asm., Shift Shaft 1 Usage
2 7043329 Spring, Tension 1 Usage
3 5251138 Plate, Slide 1 Usage
4 7043330 Spring, Shaft Return 1 Usage
5 3021877 Guide, Spring 1 Usage
6 7556443 Washer, Thrust 1 Usage
7 3514574 Bearing, Needle 2 Usage
8 5413244 Seal, Shaft 1 Usage
9 2010329 Lever, Shift 1 Usage
10 7556442 Washer, Thrust 2 Usage
11 3514601 Bearing, Needle 1 Usage
12 7510612 Ring, Snap 1 Usage
13 7556418 Washer, Steel 1 Usage
14 7556446 Washer, Lock 1 Usage
15 7518750 Screw 1 Usage
16 3021876 Shaft, Reverse Gear Idler 1 Usage
17 5335291 Pin, Grooved Lock 1 Usage
18 7556396 Washer, Dino 1 Usage
19 7518725 Screw, Flat Head 1 Usage
20 5135835 Drum, Shift 1 Usage
21 7043295 Spring, Contact 1 Usage
22 5335238 Pin, Contact 1 Usage
23 3514576 Bearing, Ball 1 Usage
24 3514577 Bearing, Ball 1 Usage
25 5135836 Drum, Shift, Locating 1 Usage
26 7518735 Screw 1 Usage
27 1332564 Asm., Locking Lever 1 Usage
28 7043298 Sleeve, Lock Lever 1 Usage
29 7043297 Spring, Lock Lever 1 Usage
30 7518734 Screw 1 Usage
31 7556398 Washer, Dino 1 Usage
32 5135834 Shift, Rail, Reverse 1 Usage
33 5135833 Shift, Rail 1 Usage
34 7043293 Spring, Pressure 2 Usage
35 5135830 Fork, Shift 1 Usage
36 5135832 Fork, Shift 1 Usage
37 5135831 Fork, Shift 1 Usage
38 3234456 Bushing, Shift Fork 3 Usage
39 6230384 Gear, Reverse, Idler 1 Usage
40 4011798 Sensor, Gear Position 1 Usage
41 5413247 O-Ring 1 Usage
42 5251137 Bracket, Cable, Reverse 1 Usage
43 7518732 Screw 3 Usage
44 5413306 Seal, Shaft 1 Usage
45 7043296 Spring, Reverse Lever Return 1 Usage
46 2010291 Lever, Reverse Lock 1 Usage
47 7556397 Washer 1
Old 12-07-2009, 05:14 PM
And welcome to the board!
Moose heated grips and thumb
2000 polaris 425 shifter shaft
broken shifter shaft
how to remove shifter for polaris 300 atv
how to repair broken gear shifter on atv
john deere gator broken shift
polaris 2000 425 atv shifter parts diagram
polaris 300 parts diagram
polaris 525 shift lever
polaris 7556446
polaris atv parts diagram
polaris atv shift rods
polaris atv shifter broke
polaris atv shifting fork
polaris outlaw 525 shift lever
polaris outlaw diagram
polaris shift fork
polaris shift lever rod broke
polaris shifter rod
shift lever for polaris 300
www.polaris 300 part diagram.com
