10-23-2011, 09:42 AM
Member #14577
front end steering help
OK so my mistake was buying a used 500 outlaw..
replaced every darn bearing and bushing on it .. rear hub still has a wobble to it ..
but anyway .. i replaced everything on the front end .. ball joints and all ..
so no one of my tires moves left to right like the linkage to the steering needs to be corrected ..
i never done that .. so if anyone understood what i just typed hahahaha
i need some help dont wanna mess it up more hahah
10-23-2011, 10:53 AM
Member #13071
there should be a type of center link in that steering setup. make sure that is all tight
10-23-2011, 11:24 AM
Member #14577
heres a vid .. i just dont want to make any mistakes .. shes a heavy mama ya know!!
10-23-2011, 03:57 PM
Member #13071
no you dont adjust it that center link is bad and needs replaced
10-23-2011, 03:59 PM
Member #14577
dang
thanks alot man ///
10-23-2011, 04:01 PM
Member #13071
dang
np man
04 polaris predator steering problem, balljoints polaris predator 500, bent front end on predator polaris 50, centrelink setup on polaris predator, changing ball joints on a polaris outlaw, hoe to tighten predator 500 steering, how to replace upper steerng bushings polaris predator 500, polaris outlaw front end problems, polaris outlaw steering, polaris outlaw steering bushings, polaris predator 500 center linl, polaris predator 500 front moves around, polaris predator moves around, polaris predator steering links, predator 500 balljoint replacement?, predator 500 centerlink, predator 500 steering bushings, steering helper for polaris atv, upper steering bearing polaris outlaw, what is the steering setup called on the old polaris outlaw?
