11-09-2011, 06:02 AM
Member #16017
Outlaw 90 Starter Problem
Hey everyone. I'm working on my father n laws 08 outlaw 90. The problem with it is that when you use the electric start, it sounds like the bendix is not engaging. Upon tear down I found that the starter doesn't have a typical bendix, but instead is connected to an idler gear, which turns a larger gear mounted on the crank, behind the primary clutch. When the starter is activated everything seems to turn normally, but it will not grab and actually turn the engine over. Has anybody messed with one of these? If you look at the parts breakdown on one, it seems like the most logical thing for me to do is replace the wheel starter assembly, as every thing else seems to work as designed. Maybe its worn to the point that it cant grab what is supposed to grab. Anyhow, ideas a certainly appreciated.
heres a video of what its doing. you can see how the set up is. the starter actually being the very small gear at the top. there towards the end it looks like its turning over, but its just rocking back and fourth on the compression stroke. thanks.
-Justin
2011 XP 850 EPS: HID's, K&N w/ Precharger, Radial Outlaws, Tunes, Strong Made Stick Stoppers
2009 Rancher 420 ES EPS: HID's, HMF, Optimizer, Full Skid Plates, OX Lite Stick Stoppers, Snorkeled, Tunes, Rear Seat/Storage, Warn M/T2500, Swamplites on ITP SS212's
11-22-2011, 07:15 PM
Member #20702
90 Outlaw Starter issues
Justin,
I am having the same issue with my daughters Outlaw 90. Did you ever figure out exactly what was happening with the starter gear/wheel and why it was not engaging? Did you replace a part?
Also, your video was fanatastic....it really helped me get a visual on what was going on.
Thanks,
John
11-23-2011, 08:59 AM
Member #16017
John,
I had a few others to get ready for this weekend, so it was put aside. Ill start working on it next week, so hopefully Ill have it figured out. Ill post my findings.
-Justin
11-23-2011, 09:06 AM
Member #20702
Thanks very much Justin. Enjoy the long weekend....hope you get some great riding in!
11-26-2011, 10:29 AM
Member #18892
My daughter's 2008 predator 90 is making the same noise while using the electric start. When you kick start it, it starts easily. I chaulked it up to her riding through some deep mud. These machines do not like mud. Thanks for the video.
"Fundamentals are a crutch for the talentless"
Kenny Powers
2011 850xp Touring LE
2009 Pink 90
2009 AC 150
11-26-2011, 03:46 PM
Member #20702
I apologize, not sure what you mean by #6.
#6 on the parts schematic?
Thanks very much for the help!
John
11-27-2011, 04:51 AM
Member #13071
yes #6 on the parts list is what your going to need to check but most likely that is why its just grinding and will need replaced.
11-27-2011, 05:00 AM
Member #20702
Thanks!
01-03-2012, 06:40 PM
Member #21923
I am trying to find starter on a 06 90. What do you have to take off to get at the starter?
2008 90 polaris starter, 2008 outlaw polaris 90 engine work though, 2009 polaris 90 outlaw want crank, 2009 polaris outlaw 90 want crank, 2009 polaris predator 90 kickstart assembly video, outlaw 90 problems, outlaw 90 starter, polaris 50cc kick start assembly, polaris 90 outlaw starter, polaris 90 starter not working, polaris 90 starter problems, polaris outlaw 90 forum, polaris outlaw 90 starter, polaris outlaw 90 starter gear, polaris outlaw 90 starter problem, polaris outlaw 90 starter problems, polaris predator 90 kick start parts, polaris predator 90 problems, polaris predator 90 starter problem, polaris relay starter assembly
