11-17-2011, 06:41 AM
Member #7423
Metal "flakes" in oil
Just bought an 08' outlaw 525's. Changed the oil in it and noticed a lot of "flakes" on the screens (mostly on the bottom screen) and a lot of shavings on the drain plug. Is this fairly common? I should have taken a pic but my hands were filthy and I didn't want it all over my iphone. I didn't notice anything in either filter but like I said, a lot in the screens and plug. Should I be worried or is this normal?
11-28-2011, 05:20 PM
Member #18040
I dont have a answer to your question but I had the same experience. I just got a used 08 a little while back. I changed the oil when I got it and it had alot on the drain plug. Its time to change the oil again. I hope to not see that again. I dont know how often the original owner changed the oil. I will report back later this week.
11-28-2011, 05:32 PM
Member #19012
Run it for a little bit with the new oil and drain it again. Do this a few times if need be and see if this flushes it out. If it continues......you'll probably need a rebuild.
11-28-2011, 05:54 PM
Member #18040
I hope it doesnt need rebuilt! The factory tires are not even wore out!
11-29-2011, 05:18 PM
Member #14933
It was probably still break in oil so it would have the flakes from break in
2011 xp850
Stealth Snorkels
30/11/14 zillas
14" Polaris pro wheels
Guru bumper
Mud tubez stereo
Epi clutch kit
Cycle country plow
3000lb winch
11-29-2011, 05:27 PM
Member #18040
I hope this is the case but if it is that means the original owner didnt change the oil
11-29-2011, 05:36 PM
Member #19012
How many hours are on the motor?
11-29-2011, 06:14 PM
Member #18040
me or the OP? If me, I am not sure. I have had mine a couple of months. I changed the oil when I first got it from the original owner. I have put about 15 hrs on it. When I got it the machine was in real good shape. It looked like it got a lot of action on asphalt from the wear on the tires.
flakes in oil atv, metal flakes in atv oil, metal flakes in oik, metal flakes in oil, metal flakes in outlaw 525, metal flakes in polaris 120 oil, metal flakes oil, metal flecks in oil atv forum, metal in atv oil, metal in my atv oil, metal in my oil on atv, metal in oil polaris, metal in outlaw 525 oil, metal shavings outlaw 525, metal shavings polaris outlaw, outlaw 525 metel, polaris outlaw 525 oil screens, polaris outlaw metal shavings
