01-25-2012, 11:41 AM
Member #22134
Cool, keep us posted!
01-25-2012, 04:28 PM
Member #19160
Something I forgot to mention is that the scrambler 50 that I had this happen on it happened super bad but only on one side. At one point I was going to switch the shocks to prove it out but then I sold it. The Predator I had both sides on Max tilt. Because of the scrambler it makes me still think it has to be in the springs or the shocks.
02-03-2012, 10:15 PM
Member #22134
Any update's Monumaker?
02-22-2012, 09:02 PM
Member #22134
Did the other models shocks work out? Whutz up....
03-12-2012, 04:01 PM
Member #24129
Hello, I dont want to come on here and be a know it all, I am new to this forum but not new to the "Camber" Problem on my sons '12 outlaw50. The resolve is set the quad on flat level ground and be sure to lift the front end and set it down smoothly. With out rolling the quad get a string and tie a loop in one end of it and place the loop around the rear brake adjuster and pull the string around the rear tire toward the front and carfully check the toe. If the toe is off even a little when you roll the quad the tires will force the suspension to travel and give the appierence of bad camber. If the Toe is set spot on it will ride level and the camber issue will go away on its own.
With only 2 lbs of air in the tire and the traction they have it only takes a little bit of Toe in or out to track this way. Look at your owners manual for a detailed look at how to set the toe. One fixes the other. And you will have to do both sides to keep the handle bars center.
Hope this helps anyone.
2011 polaris outlaw 50 starting problem, adjusting shocks on polaris outlaw 90, front end adjustment on a polaris outlaw 50, making 2012 polaris outlaw 50 faster, outlaw 50 front suspension, polaris 50 outlaw suspension, polaris 50 tires camber, polaris 90cc front wheels tilt, polaris outlaw 50 2011 front shock, polaris outlaw 50 forum, polaris outlaw 50 front camber, polaris outlaw 50 problems, polaris outlaw 50 sagging springs, polaris outlaw 50 shock spring removal, polaris outlaw 50 shocks, polaris outlaw 90 front wheel camber off, polaris predaror camber, polaris predator camber, problems with outlaw 50, problems with the polaris outlaw 50
