12-03-2011, 04:32 PM
Member #21056
Camber front end on outlaw 50
I recently bought a used OUTLAW 50. The both from tires CAMBER to the inside. Im looking to see if anybody has corrected this problem.
01-16-2012, 01:46 PM
Member #22360
I have the same problem on my '12 50. Wonder how to correct it, as its non adjusting.
01-16-2012, 09:48 PM
Member #19160
Think the only thing you can do is not overload them and get new shocks on the 50's and 90's. According to the Scrambler, Sportsman, and Predator 50 & 90 manual there are no adjustments.
If one side is lisping more than the other change the front shocks from side to side and see if the problem follows. Almost wish they would use front shocks like the rear where you can adjust the springs.
The other thing I notice on one we had when kids rode it you could see the top of the wheels tilting in, when they get off if you pick up the front end and set it back down they were perfectly aligned. So it appears to be the load on the shocks that causes it.
01-17-2012, 05:51 AM
Member #22336
My 2012 outlaw 90 does the same thing.The top of the wheels go in so bad that it looks broken.My front shocks do adjust but that don't help at all.
01-17-2012, 06:44 AM
Member #22360
Mine will do this also. When my 53 lb boy is on it its bad though. It's bad enough that my wife who knows nothing about quads asked why his wheeles were bent already. I know that it probably won't hurt anything, but this is very aggravating to me that they come this way. Of corse at the dealership it looked fine.
01-17-2012, 07:06 AM
Member #19160
Whats funny is it doesn't happen on all of them, just some. Just out of curiosity when you they are tilted in and you pick up the front end and set it down do they look back to normal?
01-17-2012, 07:14 AM
Member #22360
Yep. Even with him on it. When they are tilted in, if I pick up the front end and set it back down they look fine. As soon as he takes off... Look bent.
01-17-2012, 07:35 AM
Member #19160
Its gotta be the shocks. Would love to swap shocks from a good one to a bad one to confirm but I don't have any right now with the problem.
01-17-2012, 08:39 AM
Member #22360
Well, if it's not this way on all of them then my concerns just changed to a problem. My dealer is a member of this board, so let's see what they think it is. I'm sure they will come through, as they are the best dealership I've ever delt with. I'll keep the thread posted to what I find out.
01-17-2012, 03:19 PM
Member #22134
Yep my son's does the same thing. I wonder if the 90 models shocks will fit the 50. If so im sure the springs rates are a little stiffer and would correct the problem. Just a thought...
2011 polaris outlaw 50 starting problem, adjusting shocks on polaris outlaw 90, front end adjustment on a polaris outlaw 50, making 2012 polaris outlaw 50 faster, outlaw 50 front suspension, polaris 50 outlaw suspension, polaris 50 tires camber, polaris 90cc front wheels tilt, polaris outlaw 50 2011 front shock, polaris outlaw 50 forum, polaris outlaw 50 front camber, polaris outlaw 50 problems, polaris outlaw 50 sagging springs, polaris outlaw 50 shock spring removal, polaris outlaw 50 shocks, polaris outlaw 90 front wheel camber off, polaris predaror camber, polaris predator camber, problems with outlaw 50, problems with the polaris outlaw 50
