12-09-2011, 08:41 AM
Member #20821
outlaw 500 jetting
well i pulled the trigger last night and bought a HMF slip on for my 07 outlaw 500
The pipe is coming with a 3 new jets and HMF says to replace the stock with the 155 jet. seems simple enough.. my question is, will i also need to adjust the needle clip or the air mix screw, or should that all be ok as is? Im just adding the HMF slip on ..still using the stock filter and airbox.
This is what i bought >>>
http://www.ebay.com/itm/400249058558...84.m1497.l2649
12-09-2011, 10:24 AM
Member #21185
im in the same position as you man..i just made a thread..im buying a big gun evo for my outlaw 525 and i dont know the slightest thing about jetting!
12-09-2011, 10:27 AM
Member #20821
well if its any help, i just called HMF, they told me to just install the 155 main jet that comes with the pipe, screw the air fuel mixture screw in all the way then back it out 2 1/2 turns and i'll be ready to go. I bet if you call the company that makes your exhaust they will tell you what all need to be done too.
12-09-2011, 03:56 PM
Member #21185
i was looking at the JD jet kit that it 76$ and i called them..the kit comes with 2 different needles and 4 different jet sizes. but i dont know if its just as simple as swaping out the jet as some people to or if i have to also drop in a different needle
12-09-2011, 04:39 PM
I'll try to help. If you want to just get your A/F ratio back in the money with an exhaust, follow WIGuy's advice and call the exhaust support line. They know best.
However the $$$ sunk into that JD jetting kit is the needle. Don't spend the money unless you are going to replace the needle. Otherwise you're paying $75 for $15 worth of jets. The needle is the meat and potatoes. It'll give you better acceleration and is well worth the $$$...again IMO of 3 years behind a parts counter.
12-09-2011, 06:05 PM
Member #21185
i just changed my plan with getting the big gun evo and i bought the hmf sport for the outlaw 525..the exhaust comes with 3 hmf jets, 150,155,160..now im assuming no needle come with this? so i will just simply swap out my stock main jet for one of these? i have a k and n filter and im going to run it with the airbox lid off..so 155 or 160?
12-09-2011, 06:09 PM
Member #20821
call HMF at 866-463-7473 tell them what quad you have and they will tell you what main jet to use and what to set the air/fuel screw at. other than those 2 things nothing else needs to be done with the HMF slip on exhausts.
12-10-2011, 08:29 AM
Member #21185
call HMF at 866-463-7473 tell them what quad you have and they will tell you what main jet to use and what to set the air/fuel screw at. other than those 2 things nothing else needs to be done with the HMF slip on exhausts.[/QUOTE]
from what ive seen i saw that people were running the 155 jet and 2 1/2 turns out but i will still call anyway..also this kindof sucks bc i just had the valves and everything adjusted at a local atv shop and the thing literally starts as soon as u touch the starter button. it was always a pain in my ass to start and keep it running until it warmed up.. now by me changing the main jet and messing with that screw is there a chance its going to be messed up again?
12-10-2011, 11:54 AM
Member #20821
I think it will start and run even better once you have the new pipe on and jet it.
Its actually been years since i have piped and jetted a quad. Back in the days of 2 strokes we had to jet for everything..warm weather..cold weather..they were very temperamental. when 4 strokes started to show up with the same power as the 2 strokes it made everything a lot easier..now its EFI..even better. I still miss the smell of Klotz lol
06 polaris outlaw 500 jetting, changing needle clip location in polaris outlaw 500 carb, evo outlaw 500 exhaust, how do i jet my polaris outlaw, how to adjust outlaw 500 jetting, jd jet kit for polaris outlaw 500 irs, jetting outlaw 500, outlaw 500 evo exhaust, outlaw 500 fuel mixture screw, outlaw 500 jetting, outlaw dual exhaust jetting, piping and jetting a polarious outlaw, polais putlaw 500 needle install, polaris outlaw 500 dual exhaust, polaris outlaw 500 jetting, polaris outlaw 525 irs a/f adjustment, polaris outlaw 525 irs stock jet size, stock jets outlaw 500, what size jet for a polaris outlaw 500, what stock size main jet is in an outlaw 500
