12-30-2011, 03:13 PM
Member #21185
525 clutch problem
Recently when i would let out my clutch and give it some gas it would make a squealing noice and sometimes the tires would skip on the surface making a grinding noise. if i let the clutch out slow and barely give it gas it will grab normally. Is the problem deff in the clutch or can it be the transmission?
12-31-2011, 12:41 PM
Member #21185
any help?
12-31-2011, 01:47 PM
Member #13071
have you tried to adjust the clutch cable slack?
12-31-2011, 02:56 PM
Member #21185
well its a hydrolic clutch but theres no slack in it
12-31-2011, 06:01 PM
Member #13071
yeah i remembered that when i was on the way out the door after posting but didnt have time to change the post...lol
04 polaris 500 clutch problems, 2011 525 polaris pa, adjust a polaris outlaw 525 clutch, clutch noise on polaris outlaw 50, how to adjust clutch on outlaw 525, how to adjust the clutch on a polaris outlaw 525, how to change a polaris outlaw 525 clutch, how to replace 08 clutch polaris outlaw, outlaw 525 clutch problems, outlaw 525 common transmission problems, polaris 500 outlaw clutch adjustment, polaris outlaw 500 clutch or transmission, polaris outlaw 500 transmission troubleshooting, polaris outlaw 525 irs clutch problems, polaris outlaw cluch problems, polaris outlaw clutch problem, polaris outlaw clutch problems, predator 500 clutch adjustment, troubleshooting a polaris transmission
