Old 01-20-2012, 05:08 PM
SNEAKY's Avatar
Member #21170
what are the wires going into the thumb throttle on a 525 outlaw four?
can they be eliminated? i want to put a throttle off of a honda on mine. better feel then the polaris one.
http://dfwdirtriders.com/
Old 01-20-2012, 05:27 PM
Nope. Throttle safety switch. It wont move, it'll just pop off the rev limiter if you remove the wires.
Old 01-20-2012, 05:44 PM
outlaw_racer's Avatar
Member #22481
i am also wondering how to eliminate the wires at the throttle on an 06 outlaw 500. i'm sure it can be done but how? lol i will let you know when i figure something out
Old 01-21-2012, 03:27 PM
joshr08's Avatar
Member #13071
just unplug it and its done. You have it eliminated.
Old 01-25-2012, 10:54 PM
outlawman 525s's Avatar
Member #5124
this is for the electronic throttle control that is used bye polaris as a safety so if the throttle was to stick wide open it can electronicly over ride and shut down the quad,i have also seen for my shelf if over drawing on amps<like wrong extra lites>make the throttle stick wide open.....so don't go sticking 100 watt extra lites on erh
in the world of outlaws,we band 2gather and run as the fastest of the fast.Laughing at the yamahoppers,and the rest of them slow rides outherepilot license required,i meant firearms,two gun minimum!!!!!!!!!!!!!!!!!!!!and maybe a few grenadiersnot here
electronic throttle control on polaris 525
honda throttle on polaris outlaw
how to calibrate a electronic throttle control on a polaris predator
outlaw 525s throttle problems
outlaw thumb throttle
polaris 500 throttle safety switch
polaris atv throttle wires
polaris outlaw electronic throttle control
polaris outlaw electronic throttle control idle
polaris outlaw electroninc throttle controll
polaris outlaw etc throttle
polaris outlaw throttle safety switch swap out
polaris predator 500 electronic throttle control
polaris predator 500 throttle
polaris predator thumb throttle
polarsi predator throttle safety
predator 500 thrttle wire
predator 500 wires coming from throttle
terry thumb throttle predator 500
what are the wires in a polaris throttle
thumb throttle Thunderdually Polaris Sportsman 7 01-06-2012 03:45 PM
Thumb Throttle Problems smore79 Polaris Sportsman 5 07-22-2011 04:29 PM
850 XP thumb throttle mod question Just Plain Al Polaris XP 8 12-03-2010 04:44 AM
Twist throttle vs. thumb throttle? rsmith0801 Polaris Predator 5 03-22-2010 05:11 PM
Thumb Throttle VS Twist Grip Throttle Billster1955 Around The Garage 12 01-27-2010 07:54 PM
