Old 01-23-2012, 03:13 PM
Outlaw19's Avatar
Member #22557
Exclamation Polaris outlaw ball joints
how much does it cost to replace all ball joints and labour
Old 01-23-2012, 03:32 PM
dwhst9's Avatar
Member #11907
Send a message via AIM to dwhst9 Send a message via Yahoo to dwhst9
Remove your a-arms an have your local machine shop press them out and press in the new ball joints. Should be no more than $20-30.
Old 01-24-2012, 02:16 PM
Outlaw19's Avatar
Member #22557
is there anyway I can do them my self.
Old 01-24-2012, 02:20 PM
res2cue's Avatar
Member #15153
Not sure if your machine has struts with the ball joint inside like the Magnum, here is how I did mine.
So you need to replace your ball joints
Old 01-24-2012, 06:00 PM
factionfx's Avatar
Member #20681
The outlaw does not have struts I don't believe.
However, the best trick I have found is to use a slide hammer that is the same thread as the ball joint end. Use a long threaded nut to connect them. slide hammer them out perpendicular.
2012 Sportsman 500, Red.
Old 01-25-2012, 04:33 PM
Outlaw19's Avatar
Member #22557
Any idea how tp replace brake pads on a polaris. Im going to do them while i have everything apart.
06 polaris outlaw ball joints
atv no thread ball joint
how to install ball joints on a polaris outlaw
how to install front ball joints on a polais atv
outlaw ball joints
polaris atv ball joint
polaris outlaw 525 ball joints
polaris outlaw ball joint 525s
polaris outlaw ball joint failure
polaris outlaw ball jooint
new ball joints at 50 hrs??? skizmo Polaris XP 12 09-16-2011 03:56 PM
Moose ball joints... Iroc_92 Polaris XP 6 06-07-2011 10:52 AM
XP ball joints crimson850 ATV General Discussion 0 03-31-2011 04:56 AM
Best ball joints for polaris predator 500 06' predator 500 ATV General Discussion 0 06-07-2010 06:01 PM
ball joints Jacob bo ATV Parts for Sale 0 04-18-2010 02:53 PM
