03-12-2011, 05:35 AM
Member #12866
Originally Posted by mikegp
Well after looking in side and finding no evidence of pinging all looks great. I put the motor back in and problem went away on the first ride..Then on the next ride we started to hear it again. This time I could see the problem....Can u guess the problem...It was the stupid chain hitting the frame ..Im missing 2 teeth on rear sprocket The chain is bad and sprockets need replaced...boy do I feel stupid
I have the same exact problem with my 06. Is I hitting a black bar down near the chain? And does the chain feel like it spinning out when you gas it?
03-12-2011, 06:20 PM
Member #2947
Well my chain was hitting the silver bar at frame. My chain never skipped Just did the flop on the frame..When I removed the chain about 6 links were seized up. My new sprockets and awesome red chain make riding less worriesome.
03-14-2011, 03:10 PM
Member #12866
What rear size sprocket is stock? I need to order one too
03-14-2011, 08:07 PM
Member #2947
The rear sprocket is 38t I bought it from the dealer.
03-14-2011, 08:22 PM
Member #12866
I have 14/37. Would these run fine? And
Did the new chain and
Sprockets fix your problem
03-14-2011, 09:39 PM
Member #11691
i good tip that made my predator years better was to stock up on front sprockets.i used to bust teeth all the time...
the beauty....
2005 sportsman 400
stock everything,snow king plow,custom handle
and mounting system.
the beast.....sold
2003 predator 500 TLD
2006 trans. and gears,side winder sprockets,
pro taper countour bars and grips,cr450 brake and clutch levers,itp t-9 pro beadlocks on maxxis razor 2 mx tires,black blingstar nerf bars,shaved front and rear fenders,full red HMF exhaust system with custom heat shield,stage 2 hot cams with stock valves, jetted 450r carb with civic intake(summer) and jetted stock carb with direct bolt K&N filter(winter)
03-18-2011, 04:51 PM
Member #2947
Yah the 14/37 should run good .I tried a 13/38 because every one said to drop a tooth for the sand. I didnt like it. no top speed really. worked ok in woods.. thats why im back to 38t.
best spark plug for polaris outlaw 500, can i put 91 octane on my predator 500, outlaw 500 timing chain rattle, outlaw 5oo cam timimg, polaris 500outlaw cams, polaris outlaw 50 timing, polaris outlaw 500 cams, polaris outlaw 500 how to jet, polaris outlaw 500 octane, polaris outlaw 500 problems, polaris outlaw 500 rear boot by chain sprocket, polaris outlaw 525 sparkplug size?, polaris outlaw chain, polaris outlaw spark advance 525, polaris outlaw timing chain, polaris predator auto decompresion problem, polris outlaw valve timing, spark plug size for a polaris outlaw, timing a polaris outlaw 500, where the spark plug on a polaris outlaw 500
