13 tooth front sprocket - Polaris ATV Forum
Old 01-21-2013, 05:59 PM
mjluper's Avatar
Member #33620
Anybody running the 13 tooth front sprocket instead of the stock 14 on an outlaw 525 IRS? I hardly ever get into and stay in 5th gear. Basically I ride a lot of trails and very little top speed runs. Where I ride there's really never a reason to go 60 plus. So does that one tooth make a big difference when slow trail riding and does anybody know what the top speed difference is just because I'm curious.
Any information of changing sprockets is gladly appreciated really!
Thanks!
Old 01-21-2013, 09:45 PM
I have 2 grandsons in Lewiston ID. and they both ride Polaris ATV rigs.
Old 01-21-2013, 10:03 PM
mjluper's Avatar
Member #33620
Oh really! I love it here in the valley!
Old 01-21-2013, 11:47 PM
Welcome aboard!
Remind me what your stock gears are, front and rear?
Old 01-22-2013, 04:00 AM
shakin's Avatar
Member #33189
Rule of thumb is changing 1 tooth is the front is a 7mph change. So 1 tooth smaller should be 7mph slower. Changing 3 teeth on the rear is roughly the same as 1 on the front, so if you try it and its too low, try one or two teeth in the rear. I used to drop a tooth on my predator for woods riding, the change is fantastic! Way more usable low end power. Will lift the wheels easily (or spin a lot It kinda makes first gear a granny gear, but 2-4 are more usable!
2010 XP 850LE EPS, Polaris Front and Rear Extreme Bumpers, PIAA Aux. lights, Polaris front and rear metal rack extensions, Polaris 3500# winch, 26" Maxxis Bighorns, 60" Glacier II Plow.
Old 01-22-2013, 08:57 AM
mjluper's Avatar
Member #33620
I believe the rear sprocket is 38 I think... And the front is a 14 stock.
Shakin that's very interesting! 7 mph is quite a bit, but I really don't need to top out 5th in tight woods! The only negative that I've had about the outlaw was that first seemed a little fast/tall when going through the tighter areas or under fallen trees and such. Two more questions... Will the chain have to be shortened or anything weird like that? Also does the atv accelerate noticbly faster overall or is it just right out of the hole torque?
Old 01-22-2013, 09:44 AM
jscheel1's Avatar
Member #31272
Try your question here, better forum for Sport Riders----->Polaris Pro Riders
Old 01-22-2013, 09:47 AM
mjluper's Avatar
Member #33620
Ok thanks!
Old 01-22-2013, 10:28 AM
shakin's Avatar
Member #33189
Im not sure how the adjustment works on an outlaw, on my predator I did NOT need to shorten the chain. It seems to have a lot more torque when you drop a tooth.
Old 01-22-2013, 05:03 PM
mjluper's Avatar
Member #33620
Alright! Very cool! Is there any brands that I should avoid when buying a new sprocket? Or brands that you would recommend?
0utlaw 50 2013 14 tooth front sprocket
13 tooth sprocket vs 14 tooth on 525 outlaw
13 tooth vs 14 tooth sprocket
2013 polaris outlaw 50 sprocket change
atv 13 tooth front sprocket versus 14 tooth
does any one know what the tooth count is on polaris 90
fastest sprocket tooth sizes 525 ktm atv
polaris predator 13 tooth sprocket
polaris scrambler 500 front sprocket 11t vs 13
predator 500 13t sprocket vs 14t
what sprockets does a 90 polaris trailblazer use
what sprockets to use on my 500 outlaw?
whats the chain link count and rear sprocket tooth count 2003trailblazer250 Polaris Trail Blazer 4 07-19-2013 11:04 AM
Changing the front sprocket Ta2edphreak Polaris Predator 9 05-14-2011 08:38 AM
Front sprocket replacement gwalden309@aol.com ATV New Members 4 12-26-2010 04:18 AM
front sprocket spacer? zeyn Polaris Outlaw 0 09-25-2010 06:08 AM
Oil comming around front sprocket 03Preda Polaris Predator 10 07-01-2010 08:42 PM
