Old 07-16-2010, 04:58 PM
daman92281's Avatar
Member #5996
coolant leak
I have a 08 outlaw 525s and there is a hole i guess u could say it was that way from the factory. Its on the head i think. If your sitting on the atv its on your left side. well anyway there is coolant leaking out of it.Is this some type of overflow or is something wrong???
Old 07-16-2010, 05:36 PM
Moose heated grips and thumb
Old 11-26-2010, 09:08 PM
outlawman 525s's Avatar
Member #5124
i'm assuming it's the water pump weep hole thats driping or weeping,that's normally a indication the water pump seal is going/gone bad,or bad if flowing like a river<gushing>and radiator runs dry
in the world of outlaws,we band 2gather and run as the fastest of the fast.Laughing at the yamahoppers,and the rest of them slow rides outherepilot license required,i meant firearms,two gun minimum!!!!!!!!!!!!!!!!!!!!and maybe a few grenadiersnot here
08 outlaw water pump seal
2008 polaris 500 weep hole leaking on water pump easy fix
2008 polaris 800 water pump seal installation
2008 polaris outlaw 525 water pump
antifreeze leaking from hole in side of engine in outlaw 525\
atv radiator leak
coolant for 07 polaris 525
coolant leak repair in las vegas
how to instal a waterpump for a 2008 polaris sportsmen
polaris 400 leaking coolant water pump
polaris 525 coolant leak out of weep hole on left side
polaris 800 coolant leak
polaris atv coolant leak
polaris outlaw coolant leak
polaris outlaw leaking coolant
polaris radiator leak
water as atv coolant
where is coolant location on polaris outlaw
where is coolant on polaris outlaw
why is coolant coming out of weep holes on my polaris outlaw 525
1994 400 2 stroke Coolant leak stuey ATV Repair and Maintenance 1 06-19-2010 02:32 PM
coolant odie22 ATV Repair and Maintenance 6 06-15-2010 04:11 AM
coolant odie22 Polaris Sportsman 3 06-13-2010 04:58 PM
08 800 coolant polarisfamily ATV Repair and Maintenance 0 04-24-2010 04:11 AM
Too much coolant? dodgeram3500 Around The Garage 4 01-20-2010 06:24 PM
