Old 08-23-2010, 05:39 PM
Zickefoose's Avatar
Member #6721
07 Outlaw525IRS ticking problem(?) (?Clutch?)
Hey everyone, for starters I have a 2007 Polaris Outlaw 525IRS with an HMF pipe and not sure what else ( Don't know if it's already jetted or not ). Well, it starts just fine, it can sit for months and one tap of the button and it fires right up, then comes the knocking,ticking, or chirping, whatever you want to call it. It's be doing it for a long while now. I go it 2 years ago and starting noticing the sound shortly after that. Never really put much thought into it and figured if it's what some people say ( the clutch ) then ill ride it till it goes out completely.... only thing is, year and a half later ( with mainly back road riding ) it's still kicking, no noticable power loss, no noticable shifting problems other than a rough transition from 1st to 2nd sometimes. I have come to 3 possible problems that I can think of from hearsay and reading posts.. It's either
1. Something to do with the clutch that makes the noise ( since the noise slightly dies down when I pull the clutch in )
2. Possibly in the process of blowing up the motor ( as my stepfather has warned me of if I keep riding it... yet it's been doing it for a LONG time )
3. Or, simply all Outlaws make the noise I hear ( as some have stated in a few posts )
If anyone happens to know it would be great. I'll try to get a clip of it up sometime tomorrow so you can hear exactly what it sounds like.
OH and BWT... last summer I over filled my oil and didnt realize it untill it sputtered to a stop about 15-20min after riding. I cant tell if the noise got worse or not when I messed that up or not. But it seems to possibly have.
But anyway im looking into it because I plan on going to West Virgina to ride some wickedly nice trails over Labor Day weekend and want to make sure I don't end up with a blown motor by the end of the trip.
Sorry this is so scattered but thoughts on what to write keep popping in my head and i remember that it also bogs down sometimes at higher RPMs ( mainly 4th and 5th ) when it has plenty of full and the full switch is turned on. If I turn it to Reserve it NEVER bogs down that I have noticed. Witch seems slighty odd to me. Only problem with that is I like playing it safe and turning to reserve when I run out to be safe on making it to refill. But, kinda makes that impossible if I want to run it hard. Thanks in advance!
Old 08-23-2010, 07:12 PM
artXPman's Avatar
Member #2777
I can't say for sure, but two questions first. What octane gas are you using? Anything less than 91 will cause a pretty noticable "ping". Or, when was the last time you adjusted your valves?
Current Quads:
2009 Polaris 850 XP LE - Nuclear Sunset
Maxxis Bighorns
HMF Swamp XL & Fuel optimizer
Uni Air filter
Rath Racing aluminum front bumper
HID Light Kit
Aluminum A-arm guards all around
2009 Polaris 550 XP EFI - Mossy Oak
HMF Swamp XL
Polaris winch
PIAA lights
Front cargo box
Maxxis Bighorns
2009 Polaris Outlaw 525 IRS
Polaris Nerf Bars
FMF Factory 4.1 exhaust w/Power Bomb Header
Uni Air Filter
Old 08-26-2010, 09:36 PM
Num1Phat's Avatar
Member #6793
My 2 cents, but I'd really have to hear it for myself. The 07 Outlaw actually makes those types of noises. It's just the way they are. So, I'd have to hear it myself to determine if it's the normal stuff or something else.
2007 Outlaw 525 IRS
CT Racing Full Exhaust, JD Jet Kit, JD FCR Fuel Mixture Screw, R&D Power Bowl 2, R&D Accelerator Pump Filter, Pro Design Intake, K&N Filter, EHS Racing Lid, Dyno Tuned 47whp
Old 11-21-2010, 08:52 AM
Ironoutlaw2010's Avatar
Member #9319
I have the same some knocking sound on my 08 and can't figure out for the life of me what it is. It don't make noise when rpms are up but idling and right before take off it is definatly noticeable. I'm new to this forum thing so I guess Write back if anyone figured it out!!
Old 11-21-2010, 09:37 AM
For both of you with knocking outlaws, if you dont know the last them the valves were check, i would start there.
08 polars 525 outlaw noisey clutch
2007 polaris outlaw 525 engine noise
2007 polaris outlaw 525 motor problems
2007 polaris outlaw 525 oil and filter
2009 polaris outlaw motor noise
525 outlaw motor noise
changing clutch on 525 ktm predator
do 2007 polaris outlaws engine noise
how to adjust hydraulic clutch polaris outlaw
how to change the oil on a 2007 polaris outlaw 525
noise in ktm hydrolic clutch
outlaw 525 clutch problems
outlaw 525 noise
outlaw 525 rattle
outlaw clutch noise
polaris outlaw 525 clutch noise
polaris outlaw 525 knocking in neutral
polaris outlaw 525 problems
problem with gears on polaris outlaw 525
clutch or throttle problem? justin ATV Repair and Maintenance 3 05-31-2010 10:45 AM
2004 Sportsman 700 EFI Clutch Problem Ben2009 ATV Repair and Maintenance 4 12-09-2009 11:57 AM
Clutch Problem 05 Polaris Sportsman 700 EFI Currinjason@aol.com ATV Repair and Maintenance 5 12-06-2009 06:26 PM
2006 450 sportsman right rear ticking pgapro2010 Polaris Sportsman 3 05-13-2009 05:39 AM
2000 expitition clutch Problem cjmyers ATV Repair and Maintenance 0 05-04-2009 08:33 PM
