Old 09-20-2010, 04:07 PM
rob1994's Avatar
Member #6007
Cool outlaw 525 nothin but trouble
it has been at the dealer to get it fixed more then it has sat in the garage,i dont wanna take it back in cause they scratch the fenders all up and leave wires sticking out loose, can anyone give me an email or somethin to contact polaris factory?
Old 09-20-2010, 04:33 PM
polaris wont be able to help you much, they will just tell you to take it to your dealer.
whats been going on with it?
nevermind, i found your other thread
it was missing and backfireing when givein it gas and its been at polaris dealer for 3 weeks now, they put a new coil in it and said it ran a lil better and now theyre trying to get a polaris tech from minnosota to check it out and it seems like polaris is to supportive, when im older i think ill buy from ktm, not polaris anymore idk this is unsatisfying
i gotta ask, have they checked that is has proper jetting for you elevation and temperature?
Old 09-20-2010, 04:34 PM
rob1994's Avatar
Member #6007
it acts like the rev limiter stops it from running hard sometimes,maybe the valves need adjusted its new with about 50hrs tottal on it..
Old 09-20-2010, 04:37 PM
i know KTM recommends the valves are checked by now, but they are rarely out of spec everytime we have checked.
is it stock jetting?
how long has this thing sat at the dealership before you bought it?
Old 09-20-2010, 04:39 PM
rob1994's Avatar
Member #6007
it also back fires when u let off the gas when at a high rpm kinda, i wanna get it properly jetted and put an exhaust on it b4 i take it in to see if thats the problem,how much is an valve adjustment?
Old 09-20-2010, 04:42 PM
price on valve adjustment depends on shop, ect. should be too much. the more you strip the quad down before you take it in, the cheaper it is (ie if you take all the plastics off before it goes in so the mechanic can get straight to the motor)
you not jetted right, and i bet that is the source of all of your problems here. can you tell if its a lean or rich backfire on decel?
Old 09-20-2010, 04:47 PM
rob1994's Avatar
Member #6007
well it does have any black stuff in the exhuast end its actually really clean but not white either,im thinking that its to lean but would that also cause problem to occur sometimes when trying to make a hard pull,it runs fine on flast black top wide open except for the backfireing a little when u let off the gas it doesnt backfire alot it just does it once kinda loudly when u let off id say around 4,000-5,000 rpm range when it does it or so...
Old 09-20-2010, 04:53 PM
its just not sounding like your jetting is right. im surprised that wasnt the first thing the dealership jumped on. the coil thing makes no sense to me. do you have a KTM dealer around? or better yet a KTM/polaris dealer?
Old 09-20-2010, 05:20 PM
rob1994's Avatar
Member #6007
i dont think theres a ktm dealer near or polaris/ktm , the polaris dealer is like 30 miles away from my house lol, is it easy to put jets in it? idk wich ones i need, hmf has a jet kit with different sizes 150,155,160 hex jets, im guesing thats the main jet.im buying a performance series slip on exhaust from hmf soon.also i have put a k&n air filter on it last month it has better throttle reponse and didnt affect the backfiring problem in a bad or good way..
Old 09-20-2010, 05:24 PM
rob1994's Avatar
Member #6007
actually theres a ktm dealer like 60 miles from here
2010 outlaw jet
2010 outlaw plastics
525 outlaw plastic
525 outlaw valve adjustment
outlaw 525 backfire
outlaw 525 plastic
outlaw 525 plastics
outlaw 525 valve adjustment
polaris 525 outlaw plastics
polaris forum 525 valve adjustment
polaris outlaw 525 plastic
polaris outlaw 525 plastics
polaris outlaw 525 valve adjustment
polaris outlaw 525 valve clearance
polaris outlaw jetting at high elevation
polaris outlaw plastic
polaris outlaw plastics
polaris outlaw valve adjustment
polaris outlaw525 valve adjustment
polaris outlwaw 525 vavle adjustment
Fan Trouble ???? bmount ATV Repair and Maintenance 5 02-14-2011 04:48 PM
trouble with steering l-rod Polaris Sportsman 11 11-09-2010 04:35 PM
Starter trouble?? billfilkins Around The Garage 1 08-24-2010 11:00 AM
2 stroke trouble... Scotty dog ATV Repair and Maintenance 11 08-06-2010 10:07 AM
Having some trouble. outlaw91 Polaris Outlaw 13 01-21-2010 03:42 PM
